Box Scraper Box Scraper Vs. Land Leveler
/ Box Scraper Vs. Land Leveler #1
jeffburton
New Richmond, WI
Kubota L3540
I bought a new, bigger tractor and my old 60" box scraper no longer fits on the beefier lower links. I was looking into getting a new box scraper, but then I thought maybe a land leveler would be better. 90% of the time, I use my box scraper to level old gopher mounds in my field. Any opinions out there?
/ Box Scraper Vs. Land Leveler #2
I have a LPGS( Land Pride, Land Plane Grading Scraper) and a ROBB(Bush Hog, Roll Over Box Blade). Each one does specific jobs pretty well. The LPGS will level out my driveway. I do have to use the scarifiers, also, when working on the driveway. It will not transport material, it will not move material horizontally, it will not create a crown on the driveway. The ROBB will transport material, it can move material horizontally and can crown the driveway.
Actually, with a whole lot of practice and a hydraulic top link - my favorite implement is my Rhino rear blade. It's a Rhino 950 - 8' wide - 1010#. It will do all of the above, plus - plow snow and maintain the driveway ditches.
If you are looking at land leveling/smoothing then I would recommend the LPGS. It's the next best thing to "Plug 'n Play". Just hook it up and drag it....
If you will be working on a hard surface - like my driveway, in the summer - get a LPGS with scarifiers. The scarifiers loosen the surface and the following blades will smooth it out.
Remember - weight is your friend. A light weight LPGS will just drag behind the tractor and create sparks. It takes real weight to make a land engagement implement work right.
/ Box Scraper Vs. Land Leveler #4
I have a cat II tractor and all my implements are cat I. I use bushings all the time. Found a great deal on a 5' box blade and use it for road work just fine. It is narrower than the rear wheels, but I don't need to work edges, and it works.
/ Box Scraper Vs. Land Leveler #5
A land leveler can do what a box scraper can do, but a box scraper can't do what a land leveler can
/ Box Scraper Vs. Land Leveler #6
I respectively disagree! A leveler does a poor job of moving material, that a box blade dies well!
/ Box Scraper Vs. Land Leveler #7
This looks like the proverbial pissin match thread waiting to happen
/ Box Scraper Vs. Land Leveler #8
Perhaps, but not from me! I am of the belief that different implements like tools shine in their designed purposes. You may get by with using a different one but it would be so much easier if you got the right one for the job!
/ Box Scraper Vs. Land Leveler #9
Actually it's the opposite of that. A box scraper can transport material, fill low spots, and level. A land leveler can only level. It can't even fill holes much less transport material.
/ Box Scraper Vs. Land Leveler #10
As far as the op question? I'd get a box blade if you can do top and tilt it's a very powerful implement. If all you have is long flat driveway, a leveler will work fine, I presume. I love my top and tilt box blade set up, but it doesn't ditch very well.
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2018 DODGE RAM 2500 (A67714)
2018 DODGE RAM...
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
PALLET OF HYD HOSES (A67714)
PALLET OF HYD...
2012 CATERPILLAR 303.5E CR EXCAVTOR (A65056)
2012 CATERPILLAR...
