Box scraper questions
/ Box scraper questions #21
Oops, wrong pic. Here's the one I meant to attach.
Sedgewood
/ Box scraper questions #22
</font><font color="blue" class="small">( Oops, wrong pic. Here's the one I meant to attach.
Sedgewood )</font>
Thanks for the pics and taking time to "eyeball" your setup, in addition to your responses. I think I'll be modifying my Keen Kutter! /forums/images/graemlins/wink.gif
I'm trying to "think through" this whole lift/tilt/angle thing, because one of my "chores" will likely be smoothing down the freshly dozed road banks and getting them in good enough shape to sow some fescue seed to help prevent erosion. So, the ability to reach up onto the bank and drag down would be important...
I'm not ready to go buy a 4-in-1, having just bought a grapple bucket for clearing work and the minihoe for ditching. I'm sure I could do some of this smoothing with the mini-hoe, but it would be SLOW going...
/ Box scraper questions #23
<font color="red"> I'm trying to "think through" this whole lift/tilt/angle thing, because one of my "chores" will likely be smoothing down the freshly dozed road banks and getting them in good enough shape to sow some fescue seed to help prevent erosion. So, the ability to reach up onto the bank and drag down would be important...
</font>
Let's see if these pics help. I went out and set up these quickies. They're not very good but should illustrate the range of motion I have with the QA mounted about 20 degrees back from vertical.
This first one shows the box blade at normal level grading position.
Sedgewood
/ Box scraper questions #24
And now rotated back as far as it will go.
Sedgewood
/ Box scraper questions #25
Now rotated full forward..
Sedgewood
/ Box scraper questions #26
Now raised high to show how the tilt increases with height ie - up the bank?
Sedgewood
/ Box scraper questions #27
And finally a pic showing the box blade resting on the embankment before it. This is about as steep as I could grade pulling down the bank. Normally I do that operation with the landscape rake. In this case I roughed out that bank a coupla months ago by traversing it the long way, and dragged the fill off to rough in a woodsroad a couple hundred feet behind the photographer (me :). The project got put on a long hold when Ma Snapper came by and deposited her eggs right smack in the middle of my work. /forums/images/graemlins/tongue.gif /forums/images/graemlins/laugh.gif
Anyway, it looks like you could mount the QA plate at a much greater angle than I have mine, say 35 or 40 degrees from vertical, and end up with a better pull-down-the-bank angle and still have enough tilt the other way.
Sedgewood
/ Box scraper questions #28
</font><font color="blue" class="small">( And finally a pic showing the box blade resting on the embankment before it. This is about as steep as I could grade pulling down the bank. Normally I do that operation with the landscape rake. In this case I roughed out that bank a coupla months ago by traversing it the long way, and dragged the fill off to rough in a woodsroad a couple hundred feet behind the photographer (me :). The project got put on a long hold when Ma Snapper came by and deposited her eggs right smack in the middle of my work. /forums/images/graemlins/tongue.gif /forums/images/graemlins/laugh.gif
Sedgewood )</font>
Wow! That was a great help! Thanks so much for going out and taking pics just to address my questions...
I think I agree that I can "tilt" the QA plate closer to 30-45% or so, and still get the range of motion that I'll need. I'll have to look closer at my boxblade, but I think I can loosen and tilt the existing 3-pt hitch setup backward, then shorten the reinforcing bars that run back to the back of the box -- my 3-pt setup isn't welded like your heavier-duty blade. (This blade weighs just under 300 lbs.)
/ Box scraper questions #29
</font><font color="blue" class="small">( Still trying to decide between the 425 or 1430 or some other CUT.)</font>
<font color="red"> I don't know what jobs you plan to use your Power Trac for, but with only 3 acres, it would seem that a PT-1430 would be too much of a good thing! I'm trying to visualize what a homeowner would want to do that a PT-425 couldn't handle!!
I have 10 mostly wooded acres, and a PT-425. In less than 1-1/2 years I have:
Prepared a 60'x70' building site from a hillside.
Dug 160' of utility trenches 30" deep with MiniHoe.
Cut ~800' of edging trenches 6" deep with Stump Grinder.
Built new 120' scenic driveway through virgin woods.
Spread gravel on ~800' of driveway.
Cleared and burned ~4 acres of ice storm felled trees and branches with PT Grapple Bucket.
Built and maintain ~1/4 mile of hiking trails with Brush Mower.
Removed old sod and installed new lawn.
Removed ~40 stumps with Stump Grinder.
Spread ~15,000# of mulch.
Planted ~40 trees and shrubs with Stump Grinder.
Installed ~35' of brick paved paths.
Plowed 20'x40' garden with Potato Digger.
Loaded pallets into the back of a tractor trailer.
I even installed a
on my front porch!!
<font color="red"> PS: What 'some other CUT' could do all these jobs with the ease, speed, safety, efficiency, and FUN of a PT-425????
</font>
</font>
/ Box scraper questions #31
<font color="red"> I don't know what I have missing or what I am doing wrong but I have never been able to see any pictures in your links. </font>
Are you on a dial-up connection? That site may load a little slow cause it has a fair amount of content loading up on the first page.
/ Box scraper questions #32
</font><font color="blue" class="small">( I don't know what I have missing or what I am doing wrong but I have never been able to see any pictures in your links. )</font>
I see the same in MSIE, but it works fine with netscape. Maybe I have some sort of setup problem with MSIE, but it works on everything else.
/ Box scraper questions #33
Microsoft, despite having signed the World Wide Web Consortium (W3C) agreement on browser standards, continues to produce IE with non-compliant HTML extensions. Since most web authors use and test with IE, and often use Microsoft web authoring software to boot, these extensions sometimes cause problems for people using other browsers, even though their browser meets W3C standards.
This time the shoe is on the other foot. The reason some people can't see the photos is simple. It is because you are using a non W3C compliant browser, MSIE. /forums/images/graemlins/smirk.gif
/ Box scraper questions #34
i have been using mozilla foxfire web browser for over a year now and i love it , its safer surfing with less security flaws and loads great but best of all its being upgraded all the time and one more plus its freeeeeeeeeeeeeeeeeeeeeeeeee lol
/ Box scraper questions #35
</font><font color="blue" class="small">( i have been using mozilla foxfire web browser for over a year now and i love it , its safer surfing with less security flaws and loads great but best of all its being upgraded all the time and one more plus its freeeeeeeeeeeeeeeeeeeeeeeeee lol )</font>
uhmm, hate to break it to you, but Internet Explorer and Netscape browsers have also been free since day one. I wouldn't use that paticular arguement to lure new users into the fold.
/ Box scraper questions #36
This may be splitting hairs (OK it is /forums/images/graemlins/wink.gif) but Explorer is useless unless you own a version of windows - which is not free. Firefox is available for linux - which is free.
/ Box scraper questions #37
.....and Firefox is much more versatile! I will always give a non MS product a shot...still, MS has a lot of good software!...but I don't think they make tractors?? /forums/images/graemlins/grin.gif
/ Box scraper questions #38
Has anyone tried to make a homemade box blade or box scraper? I am thinking this might be pretty simple, but I may be wrong.
/ Box scraper questions #39
Bob, I don't think it would be that difficult to build. It is used mostly in the pulling made. Someone makes a roll over unit, that would work quite well. One side tears or rips up the ground, and the other side spreads the dirt . You pull a cable, or lever to select mode.
/ Box scraper questions #40
I need some plans or pictures or something to base my design on. I could go to a store and take pictures, I guess. Any other thoughts.
2014 INTERNATIONAL LF687 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2014 INTERNATIONAL...
2011 KUBOTA KX91-3 SERIES 2 EXCAVATOR (A64279)
2011 KUBOTA KX91-3...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
MILITARY STYLE S/A CARGO TRAILER (A63291)
MILITARY STYLE S/A...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
