Box scraper questions
/ Box scraper questions #61
BobRip said:
Moss, thanks for your input. It just came to me that a universal adapter that would fit between the PT and the attachment so that any attachment could be tilted. That way it would not hold up the building of the box scraper and if it did not work, no big deal. Just thinking out loud for now. I don't have a spare QA plate at this time for that purpose, so it might be awhile. With the equipment I have this could take a lot of time. It sounds like I need a milling machine to cut the slots. There might be other options, so if anyone has suggestions let me know. I could drill several holes and have stepped adjustments.
You could build it out of a truck wheel hub and rotate it with a hydraulic cylinder. Just keep the weight of it down so it does not take away too much from the lift capacity.
/ Box scraper questions #62
Good idea. What do you think of a bolt in the center with slot along part of the radius and other bolts in those. Loosen, adjust and tighten bolts. If you use about 1 inch bolts and had a total of three, I think that would do it.
I got home tonight and Clint had not built my garage yet. He did get a job today, so congradulate him. He no longer works for me, so he can start giving me a hard time.
/ Box scraper questions #64
Bob, Check out the attachment plate and beam on your brush hog. If you could attach the beam to your box blade and rig up some stops like you were talking about, it might work. Not sure what PT would charge for that plate and beam but I'm going to call them when I get a chance because I'm thinking of having one welded to the snow plow so I don't have to keep fiddeling with the tilt to keep the plow blade on the ground.It would float side to side.
/ Box scraper questions #65
Yes, I like that. Maybe I could use the one on the bushhog and then put an adapter on the bushhog. So I would already have the expensive parts from the bushhog.
/ Box scraper questions #66
I have the box scrapper operational and testrf it out today. It seems to work as good as the PT one and no welds or metal were damaged during use. I have attached a few pictures. I always wonder if it will be strong enough. Any comments on that would be appreciated. I have not put the two inch receiver on it yet. I am concerned it might interfere with the operation.
I still need to put the little scape blades and support bar on. Does anyone know where I can get these or a good way to make them
/ Box scraper questions #67
Very nice job. With the weight you have a perfect scrapper.
PJ
/ Box scraper questions #68
I picked it up today with the help of a neghbor and it feels like about 150 pounds. I don't have a way to weigh it.
/ Box scraper questions #69
I added a brace across the back. PT has one and even though it seems very strong without, I did not like having the side wings floating in the back. See the attached picture.
/ Box scraper questions #70
I painted the box scraper. I still need to add the scarcifiers. Does anyone have any suggestions on getting these. I have an old cultivator that I could take the blades off of. Would this work?
Edited: Added picture of cultivator at 4:01 PM EST
/ Box scraper questions #71
Why not use the ripper shanks that are made for box blades. Most any tractor place will have them, or go to TSC. You would have to fabricate something to set them in. On my box blade, the shanks are stored in the slots that are used for digging. A 5/8 pin slides through the shank to store or dig. The shanks cost between $15 and $22.
/ Box scraper questions #72
A guess cost is the main reason. If I can use what I have that's better.
I did a search on TSC and did not find ripper shanks or scarifiers.
We do have some tractor places close by, and I can look there. Do you see anything wrong with the little cultivator blades? The look pretty tough. The shaft is about 3/4 diameter or larger.
/ Box scraper questions #74
Beechwood, thanks. I looked at the site and they look pretty good. I still hoping to get some comments on my cultivator parts. May father-in-law kept this thing for 40 or 50 years and I hope to get some use out of it. I think he would have liked that. I may try it anyway and see how it works. It will be bolted in and can be changed if needed.
/ Box scraper questions #75
I took a few closeups of the cultivator blades today. I think that I can use the blades and the main bar as part of the box scraper.
/ Box scraper questions #76
I have added three of the cultivator blades to the box scraper. It looks to me that it could use two more. What do you think? See attached pictures.
/ Box scraper questions #77
Bob Rip,
I don't know about the blades, but I was wondering how it does in leveling?
I had some small size stone delivered for my driveway, and leveled it with the back side of the bucket. I kept it in float. But it took quite a while to get it fairly level.
/ Box scraper questions #78
ldabe said:
Bob Rip,
I don't know. My driveway is already in pretty good shape. It does take a while to level with this setup, or so I am told. I have used the backside of the bucket in the past. One thing I really like about it is pulling gravel back on the driveway that has been thrown off. The side plates make this very efficient.
/ Box scraper questions #79
ldabe said:
Bob Rip,
I have used the box blade to level many areas of my yard and it does a great job. This is an attachment that takes some getting used to but when you master the leveling using the auto float it will do the job you need.
PJ
