Box scraper basics
/ Box scraper basics #41
Gordon,
I have to say I am right with you, since I sometimes wonder if I have used too-many "I"s in the sentence I have written and so I end up thinking I had better say I am sorry that I have done so, which I suppose helps, although I can't really claim that I know it does for sure, ... Know what I mean?
Maybe if I would stop using "run-on" sentences it would be easier to limit the pronouns!
/w3tcompact/icons/laugh.gif
Larry
...or, as Crocodile Dundee might say " That's not too-many "I"s,... THIS is too-many "I"s!
/ Box scraper basics #42
<font color=blue>I just left the 3-point hitch all the way down and drove forward and backward adjusting the top link as I went</font color=blue>
Rub it in, you hydraulic mad-man, Bird! /w3tcompact/icons/laugh.gif
Actually I'm glad to hear that the tip 'n' tilt is working so well for you. My wish list is growing way faster than my budget, and as much as I want to hydraulicize my top link, it looks like it's going to have to wait for more pressing issues. The rains out here have really started the weeds a-growin', which means I'd better get a sprayer real soon. I think we're finally going to get break in the weather so I can go check out the property this weekend. My fear is that it's time for the sprayer now /w3tcompact/icons/frown.gif. Hmmmmm. But with all the rain, the ground is probably too soft and squishy to drive my tractor on. Oh, well. I can always try out my rotary cutter in a few weeks. /w3tcompact/icons/wink.gif
With all this talk about box scraper angles and stuff, and knowing that you are now digitally enhanced, is it possible to get pictures that would shed some light on the controversey? Might be kind of a trick to photograph.
But that reminds me -- if you're taking requests (not that you said you were), I would be plumb tickled to see snapshots of your TNT at its various extremes. That is, side views of your box blade tipped all the way forward and all the way backward, and maybe a rear view showing maximum tilt.
Not too pushy, huh? /w3tcompact/icons/smile.gif
/ Box scraper basics #43
<font color=blue>possible to get pictures</font color=blue>
Harv, I'll see if I can do that this afternoon or this weekend. Of course, I've gotten the tractor and implements really dirty and just parked it back in the shop day before yesterday. I thought I might be using it again yesterday, but instead had to spend all day working on my (barely) paying job.
Incidentally, while we had that cylinder apart to fix the leak, we shortened it another inch. The original manual cylinder was 17" collapsed and 27" extended (measuring center of pin to center of pin). The hydraulic cylinder was 20" collapsed with an 8" stroke. So now it's 18" collapsed. It'll tilt forward as much as, or probably a little more than, needed. And it'll definitely tilt back more than needed.
And I was hoping another day or two of sun and it'd be dry enough to mow, and the yard needs mowing bad. However, more rain is supposed to get here in a couple of hours./w3tcompact/icons/frown.gif
Bird
/ Box scraper basics #44
<font color=blue>I've gotten the tractor and implements really dirty </font color=blue>
Oh, NO!!! /w3tcompact/icons/shocked.gif We can't have pictures of dirty tractors! People might get the idea you use it for real work! /w3tcompact/icons/laugh.gif
<font color=blue>had to spend all day working on my (barely) paying job.</font color=blue>
Funny -- that seems to be my mantra lately, too. /w3tcompact/icons/frown.gif
<font color=blue>more rain is supposed to get here in a couple of hours</font color=blue>
Sounds like we're running the same weather patterns. In fact, it sounds like you've had the same general conditions as we've had all winter. I never realized that the Dallas area was synchronized with the S.F. Bay Area. Your weather is bigger, of course. /w3tcompact/icons/wink.gif
/ Box scraper basics #45
Harv, I needed to take the FEL and box blade off this morning, so I snapped a couple of pictures of that dirty sucker first. With the blade tilted all the way forward, it rests on the sides and even the front blade is 2.25" off the surface.
Bird
/ Box scraper basics #46
And I have no idea what I did to screw up that picture, but here's one with the blade tilted all the way back and that leaves the front blade 2" off the surface.
Bird
/ Box scraper basics #47
So while I was at it, I snapped one of the tooth bar on the FEL.
Bird
/ Box scraper basics #48
A question for you Bird...
When you've got the box tilted all the way forward does it actually ride on the side plates, or do they dig in and let the cutting edge get a bite?
/ Box scraper basics #49
<font color=blue>I have no idea what I did to screw up that picture</font color=blue>
That's an odd one, all right. Did it look that way on your computer before you uploaded it?
Good shots, though. It never occurred to me that the sides would bottom out if you tilted too far forward. I guess that supports the "small adjustments are best" theory. I think the back-tilt picture demonstrates pretty clearly that an extended top link is what you want for smoothing operations, especially if the front blade is clear off the ground as you say.
And the tooth bar -- man, I didn't really think I was interested in one, but the more you guys talk and show pictures, the more I think it would help me in my up-coming projects. Digging out my "muddy road" stretch when it dries out, for example.
Guess I'd better get back to making money. /w3tcompact/icons/crazy.gif
Thanks for the rapid response on the pictures, Bird. It's almost like being there. /w3tcompact/icons/wink.gif
/ Box scraper basics #50
Rob, they dig in and just cut a little narrow trench, unless of course, you're on a really hard surface. And you can tilt it back a bit to lift the sides of the box off the ground and still be cutting with the front blade.
Bird
/ Box scraper basics #51
<font color=blue>Did it look that way on your computer before you uploaded it?</font color=blue>
Harv, when I first looked at it and resized it, I didn't notice anything unusual, but when I posted it and saw how big it was, I quickly deleted that message, resized the picture again to make it smaller and posted it again, and darned if it ain't still a bigger picture than I wanted. I do have one idea of something I may have messed up on. I first started to copy all the pictures from the camera to my hard drive, then realized some of them had already been copied, so I cancelled the copy, selected only the 3 new ones, and copied them to the hard drive. Maybe somewhere in the copying from one to the other, I got a double exposure?
Bird
/ Box scraper basics #52
Bird, what happened to the dirty tractor pictures? Those pic's looked better than my tractor does on a clean day./w3tcompact/icons/smile.gif
A clean day meaning right after I put the pressure washer to her. A dirty day is a couple of inches of mud caked on her. Sometimes it's hard to tell she's orange and not a brown black mix.
Gordon
/ Box scraper basics #53
Gordon, you have to remember that in this part of the country we've been used to playing in dust not mud until lately./w3tcompact/icons/wink.gif Of course my place looks like a swamp again after another inch of rain today./w3tcompact/icons/frown.gif
Bird
/ Box scraper basics #54
<font color=blue>Maybe somewhere in the copying from one to the other, I got a double exposure?</font color=blue>
Cancelling in the middle of a download might screw up an image -- it shouldn't, but then there's no such thing as perfect software. /w3tcompact/icons/tongue.gif I wouldn't worry about it unless it happens again.
I guess we just fell out of synch, weather-wise. The rain they promised us today never happened. I tell you, I just gotta find me a job like the weathermen out here. Imagine being wrong as often as they are and still getting paid. /w3tcompact/icons/wink.gif
/ Box scraper basics #55
All it means is that things are going to be dry enough to catch up on road work. Hey I'm glad we have a weekend w/o rain! According to the weather guy this morning, it's the first weekend in five weeks we won't be getting rain. Summertime, here we come!/w3tcompact/icons/smile.gif
The GlueGuy
/ Box scraper basics #56
<font color=blue>it's the first weekend in five weeks we won't be getting rain.</font color=blue>
And that's exactly why I'm going to see my tractor for the first time in five weeks! /w3tcompact/icons/smile.gif
I also haven't seen the property in that period of time, so I'm a little anxious to see how the culverts held up, how the weeds are growing (still don't have a sprayer), and whether the ground will be firm enough to bring my 'Bota out into the sunlight.
They say the weather might hold for at least a week or so, so I might just have to make an extra "work" trip next week to get some tractor chores done. /w3tcompact/icons/wink.gif
Lot of (4) Square Tube Gates (A66408)
Lot of (4) Square...
Case 1044 Combine Head (A65640)
Case 1044 Combine...
2022 EZ-GO ELITE...
2019 TAKEUCHI TL12V2 SKID STEER (A65053)
2019 TAKEUCHI...
Sand Blast Pot (A65579)
Sand Blast Pot...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
