Grading Box Blade
/ Box Blade #3
I have a 1510D and everyone said 4 foot. A good rule of thumb seems to be to get implements that are close to the same width of the tractor. Especially if they are heavy or ground engaging.
/ Box Blade #4
The contractor I bought my 2000BD from said he was getting rid of it because it couldn't do what he wanted with a 5ft blade. So I got a 4ft, and
find that it handles it really well, so well that it might handle a 5ft. He didn't have any weights or loader on it, so the front was light. I only have the loader for weight, which seems to work for the 4ft blade. Kind of close on the tire tread width for a 2000, but not worth it to trade up.
Point of my rambling is this, weight distribution is something to consider in your blade selection.
Jerry
2000BD, Koyker 120
/ Box Blade
Well, I have a loader so I think I am OK on weight on the front. It seems that the wisdom is to go with a 4 ft but I would like to have the extra width of a 5 footer for the same cost. I don't really have enough experience with the tractor yet to judge the ability to use a larger implement.
Thanks
Kendall
/ Box Blade #6
Most people will say 4'. I have a fairly heavy 5' and the 1500D+FEL seems to do rather well with it. It won't bog down until about 3/4 full depending on soil conditions and if the ground is level. When I was dehumping my road I had it over filling going down a gentle slope. If you are trying to smooth out some rough ground it is nice to have your tires covered, so when you hit the same area a second time your wheels are on more level ground. I guess it depends on what you are going to do. If you are going to move mountains then get a 4' if you are just trying to smooth out some shallow dimples and want more coverage area per pass get a fiver...
CHECO GREASE UNIT (A67714)
CHECO GREASE UNIT...
2014 TROXELL 130BBL VACUUM TRAILER (A67714)
2014 TROXELL...
2013 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2013 ALLMAND...
2022 John Deere 3025E (A64911)
2022 John Deere...
2019 GMC Sierra 2500 (A64911)
2019 GMC Sierra...
2025 32in Bucket Mini Excavator Attachment (A66734)
2025 32in Bucket...
