Box Blade Weight
/ Box Blade Weight #1
Ordtech
Massey Ferguson 1835M
I Have a MF 1835M looking to get a Box Blade. Woods BSS72 or the BSM72. From what I can tell the only difference is 130 lbs. Most talk is heavier is better. Does that apply here.
/ Box Blade Weight #2
The bsm is built heavier. Heavier steel, side plates, etc. Woods rates it to be pulled behind bigger tractors.
/ Box Blade Weight #3
Get the BSM72 with the floating tailgate:
/ Box Blade Weight #6
A heavier box blade is going to be much less finicky in terms of technique required to get it to do its job. I added 110 lbs to my 5' box blade. A heavier blade needs less 'messing with', both on the tractor seat and off. Then there's the durability benefit. Yeah, it's a total win as long as your 3pt can lift the thing even when its packed full of material and get it to dump it out. That's the limit I run into with my tiny B6100.
I have another project tractor with a 3pt that can lift 2000lbs. But, if i hooked a 1000lb box blade to it it might not have traction/power to pull it. Adding weight will make the same width work better, but adding width will make the traction/power requirement go up a lot faster than the weight. You don't want to add weight by adding width. More weight in the same width is good
/ Box Blade Weight #7
AND with a hydraulic top link - using that heavier box blade will be a pleasure.
Kubota RTVX1100C (A64127)
Kubota RTVX1100C...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
1995 Kiefer Built Gooseneck Trailer (A66285)
1995 Kiefer Built...
2022 EZ-GO ELITE...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
