Box Blade Weight
/ Box Blade Weight #1
Ordtech
Massey Ferguson 1835M
I Have a MF 1835M looking to get a Box Blade. Woods BSS72 or the BSM72. From what I can tell the only difference is 130 lbs. Most talk is heavier is better. Does that apply here.
/ Box Blade Weight #2
The bsm is built heavier. Heavier steel, side plates, etc. Woods rates it to be pulled behind bigger tractors.
/ Box Blade Weight #3
Get the BSM72 with the floating tailgate:
/ Box Blade Weight #6
A heavier box blade is going to be much less finicky in terms of technique required to get it to do its job. I added 110 lbs to my 5' box blade. A heavier blade needs less 'messing with', both on the tractor seat and off. Then there's the durability benefit. Yeah, it's a total win as long as your 3pt can lift the thing even when its packed full of material and get it to dump it out. That's the limit I run into with my tiny B6100.
I have another project tractor with a 3pt that can lift 2000lbs. But, if i hooked a 1000lb box blade to it it might not have traction/power to pull it. Adding weight will make the same width work better, but adding width will make the traction/power requirement go up a lot faster than the weight. You don't want to add weight by adding width. More weight in the same width is good
/ Box Blade Weight #7
AND with a hydraulic top link - using that heavier box blade will be a pleasure.
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
20ft T/A Utility Trailer (A64557)
20ft T/A Utility...
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
Steiger Panther 3 ST320 (A64911)
Steiger Panther 3...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
