Box Scraper Box blade technique
/ Box blade technique #1
jezorek
NJ
Ford 1910 w/1710 FEL
After reading about the utility of box blades in this forum, I bought a heavy duty 6ft BB to repair the run off damage to my woods roads caused by the recent nor'easter in NJ. Without bringing in fill from some where, it appears that filling the gulleys caused by the run off will involve dragging the road and filling with the dragged soil. This has the over all effect of lowering the road bed createing banks on either side. I assume that I will have to create some camber in the road to direct future water flow. Widening and creating a proper ditch is impractcal due to the adjacent trees.
It is not obvious to me how to put in the camber with the box scrapper. I welcome your suggestions.
/ Box blade technique #2
Lower/raise the adjustable side of your 3 point hitch and grade the road with the high side to the middle.
You're in a bit of a jam if you can't cut ditches and you don't have enough material to elevate the road bed.
A road without ditches is a ditch.
Jeff,
Without down pressure on the lift arms, does it really make any difference to raise or lower one side. Why dosen't the BB just follow the existing contour?
/ Box blade technique #4
There's no down pressure, but the blade will be at an angle right to left. Try it. The arms do not float independently.
That said, when the box gets very full on the low side, it starts to loose its effectiveness. Light cuts, careful attention, and patience are needed.
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
1500 GAL WATER TANK (A68842)
1500 GAL WATER...
2006 MACK CV713 (A67714)
2006 MACK CV713...
2017 Freightliner M2 106 Passenger Bus (A66736)
2017 Freightliner...
2015 WILDWOOD 5TH WHEEL (A67714)
2015 WILDWOOD 5TH...
2012 CHEVROLET SILVERADO 1500 (A67714)
2012 CHEVROLET...
