Box blade suggestions
/ Box blade suggestions #21
That isn't necessarily true. I have brochure here from back when the 4X10 series was introduced. They show the tiny 4010 be compatible with an 8' box blade. Nobody in their right mind would believe that, yet it's right there on page 25. Point is, just because JD info might say it somewhere doesn't necessarily make it true.
The 1 series may have enough power for a 5' BB, but traction/weight is much more of a limiting factor than lift capability or HP. Use a 5' wisely and you won't have too many problems. Just don't try to make a big tractor out of a little one, and load it to the max.
True. You can't make a small tractor into a big tractor.
I'm heading out to pick up the Mahindra 4' BB tomorrow morning. It's not a clevis setup, but I think after its initial use it won't be used much. I'll take my chances with the cheaper setup and hope for the best.
The R4s on the 1025R are a few millimeters wider than the turf tires per the brochure.
/ Box blade suggestions #23
That is fine it is not a clevis hitch. You will not hurt it with a small tractor.
2017 CATERPILLAR 335FL CR EXCAVATOR (A65056)
2017 CATERPILLAR...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2019 FREIGHTLINER...
Unused 2026 CID SNLB84-S 84in. Snow/Ice Skid Steer Bucket Attachment (A66734)
Unused 2026 CID...
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
