Box blade suggestions
/ Box blade suggestions #21
That isn't necessarily true. I have brochure here from back when the 4X10 series was introduced. They show the tiny 4010 be compatible with an 8' box blade. Nobody in their right mind would believe that, yet it's right there on page 25. Point is, just because JD info might say it somewhere doesn't necessarily make it true.
The 1 series may have enough power for a 5' BB, but traction/weight is much more of a limiting factor than lift capability or HP. Use a 5' wisely and you won't have too many problems. Just don't try to make a big tractor out of a little one, and load it to the max.
True. You can't make a small tractor into a big tractor.
I'm heading out to pick up the Mahindra 4' BB tomorrow morning. It's not a clevis setup, but I think after its initial use it won't be used much. I'll take my chances with the cheaper setup and hope for the best.
The R4s on the 1025R are a few millimeters wider than the turf tires per the brochure.
/ Box blade suggestions #23
That is fine it is not a clevis hitch. You will not hurt it with a small tractor.
2023 Landmaster L5W (A64912)
2023 Landmaster...
HLA HD42 48in. Forks and Frame Skid Steer Attachment (A66734)
HLA HD42 48in...
1990 Ford F700 (A64911)
1990 Ford F700...
213141 (A64276)
213141 (A64276)
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 HINO 195 18FT...
