Box Blade suggestion
/ Box Blade suggestion #1
Ezzrider
Kubota B7510
I own a Kubota B7510 Diesel 4x4 tractor. I need a box blade for use around my property. Any suggestions as to the recommended width and weight given my size tractor?
/ Box Blade suggestion #2
I have had a 7510 for 5 years now. Most of my implements are only 4' wide. I kept them to 4' for maneuverability. Last year I purchased probably the most useful tool other than the FEL. That being a 5' wide Armstrong Ag Land Plane.
Everything Attachments has them pictured on their web site as well as a video of one in use. If you want your finished project to be level use a land plane. If you want to move dirt from one place to another use a box blade or FEL if you have one.
Tractor Land Plane - Tractor Land Leveler - 3 point Hitch
/ Box Blade suggestion #3
BTW I have an 800 lb aerator that the 7510 will lift, but just barely. I would say the weight on the blade should be around 400 lbs, not more.
/ Box Blade suggestion #4
4' wide, 400-500lbs. Much lighter than that and it won't be very effective at anything but light work.
I have a 5' box blade that weighs about 450lbs that I use on my B3200. Tried it on the B7610 that my mother has and it worked ok, but you couldn't pull a full load of dirt well with the scarifiers down. I think 4' wide would be ideal.
/ Box Blade suggestion #5
I have a B2320 with a LP BB1548 great bb really heavy duty. The bb weight is 435 lbs. I have unloaded tires in the rear and I will slip traction from time to time. When I know Im going to be doing a lot of heavy work I fill the FEL with a scoop of #67 gravel out of my pile. this gives me a lot more pulling power in 4wd.
Well I guess I would be needing to level out dirt so maybe the land plane would be better? I have the front end loader with a bucket on it but no other dirt moving attachements.
2025 Grapple Rake Mini Excavator Attachment (A61572)
2025 Grapple Rake...
JCT 72" VIBRATORY ROLLER (A64281)
JCT 72" VIBRATORY...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
generator trailer (A61569)
generator trailer...
(2) 8 LUG TRAILER AXLES (A64280)
(2) 8 LUG TRAILER...
