Box Blade Size
/ Box Blade Size #1
jrepp
North West Louisiana
Kubota L5030HSTC
If my outside rear tire width is 6' do I want a 6' box blade that matches the tire width, or a 7' that spans an additional 6" on each side of the tires? Box blade used mostly for dirt road maintenance.
/ Box Blade Size #2
Since you have the 5030, I'd go with the 7 footer.
/ Box Blade Size #3
I agree with Billy and would go for the 7' unit. You have the power and tractor weight to pull it and that extra 6" on each side is handy when working close to things. Also check the weight of the boxes you look at. With a boxblade the more weight the better it will work for you. Regardless of tractor power I would never buy a box blade that was narrower than my rear tires.
Sure wish I had the kind of muscle the L5030 has at times.
MarkV
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
Excavator Tooth Bucket (A62177)
Excavator Tooth...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
McCormick X6.55 (A62177)
McCormick X6.55...
DSP 900 Balancer with Split Weight (A63118)
DSP 900 Balancer...
2013 International WorkStar 7400 Altec Bucket Truck (A61568)
2013 International...
