Box Blade - Rollover
/ Box Blade - Rollover #1
roysallis
Alabama
JD 5210, JD 521 Loader, JD MX6 Rotary Cutter, TufLine 6' Disk, TufLine 6' Grader Blade, TufLine 6' Box Blade
Anyone have and info on a rollover box blade made by Gill?
/ Box Blade - Rollover #2
I have a Woods brochure (they bought Gill) and I have seen one. Best feature is they can go from level to scarfier in a few seconds. Worse feature is that cost more than one that doesn't do this. They are also heavy and that IS good. /w3tcompact/icons/smile.gif
wen,
Thanks for the info. I will be looking at a used rollover blade this afternoon. The seller says that it has been kept inside and that it is a heavy blade. If Woods bought out Gill then maybe it is a good one. The asking price is lower than the cheap regular blades that I have looked at. Maybe I had better get this one.
Thanks again.
/ Box Blade - Rollover #4
Gill has been building rollover scrapers for many years and they are practically indestructible. Rollovers are typically heavier than a comparable width standard box scraper. For example, my Woods/Gill 60 inch rollover has a spec weight of 730 pounds. The standard Woods 60 inch box scraper shows a spec weight of about 460 pounds.
/ Box Blade - Rollover #5
If the asking price is less than a cheap box and its in decent shape jump on it you won't be disapointed with your buying decision. Good luck
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2005 Isuzu NQR 4 door box truck with folding gate (A63689)
2005 Isuzu NQR 4...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
