Grading Box Blade question
/ Box Blade question #1
gmoney
I am in the market for a box blade (48") for my 2305. Main use will be to maintain my gravel driveway. I am leaning toward the JD model BB2048L which I can get from my local dealer for $675. In looking at this model and others, the JD model has 3 ripper shanks while the others have 4. Will the JD box blade with less shanks perform as well as others with more shanks (same width)? Or is there more to the picture than just the number of ripper shank??
Thanks for the input!
/ Box Blade question #2
For maintaining a gravel driveway I doubt you will even use the ripper shanks. Just turn them upside down out of the way. If you are just starting a driveway from bare ground use them to tear into the turf as the first step to grade the dirt. The number of shanks is not important, other than the more you have down the more horsepower it takes to pull.
/ Box Blade question #3
I have a Buhler/Farm King 48" box blade and love it. It is heavy and very well built with 4 rippers. I use the rippers all of the time. The rippers chew the packed material up so that it can be spread out and packed down evenly. Rips the weeds out too. It's not specific for a sub cut but with the Imatch on it has plenty of height when lifted. This box is a good 400lbs and makes the driveway look like new. It does take a bit of practice thouigh. If the blade with 3 rippers is not as heavy that's the reason for 3. You need weight to drive them down into the hard pack.
/ Box Blade question #4
We sell the medium duty 4 ft. Hawkline for $395 with 4 shanks. Pictures and specs are below. Ken Sweet
/ Box Blade question #5
way too much money IMO...if you shop around you will find a much better BB for a lot less money...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2022 EZ-GO ELITE...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
