Box Scraper Box Blade Question...
/ Box Blade Question... #1
bwmarine
western michigan
cub cadet 7235
Now I am a proud owner of a box blade and have never used one... time for a stiff learning curve.
I relize I will need to just use it to figure out the best setup for my uses, the question is...
The box blade that I aquired has the hinged door in back... what are the pros and cons of the hinge door verses the standard version? Is one better than the other in different senarios?
Thanks for any input!
/ Box Blade Question... #2
The questions that you ask are not new questions. The debate about the hinged rear blade has a variety of opinions pro and con. In short because it is hinged it will allow the front blade to get a better bite when you want to dig in, but it is harder than to spread the material by lengthening the top link and having the BB riding on the rear blade.
As far as learning to use it my main recommendation would be to use it. You will learn best by doing in this situation. I do recommend starting in a non-critical spot with lots of room. You can also read up on these threads for great information on the use of a BB and their capabilities.
http://www.tractorbynet.com/forums/attachments/122762-beginners-guide-using-box-blade.html
http://www.tractorbynet.com/forums/attachments/136670-techniques-basic-box-scraper.html
http://www.tractorbynet.com/forums/attachments/117058-box-blade-hinged-back-why.html
http://www.tractorbynet.com/forums/attachments/116592-adjusting-three-point-hitch-new.html
http://www.tractorbynet.com/forums/owning-operating/116316-various-boxblade-uses.html
Well that ought to be enough to give you some reading material and guides for your beginning practice. Have fun.
Mike
Hey mike, thanks! I will read through the links you gave me. I thought of searching the forum but I figured there was a lot of material but to find the useful info that I am looking for.
I was hoping for a simple answer lol........... thanks mike
/ Box Blade Question... #4
I have the old style (non hinged) in a 6' for the reason you state and I really like it but I want to get an 8' medium duty but it doesn't seem that anyone makes them. Bush Hog makes the old style in light duty blades (7' max) but not the medium duty.
Ken
/ Box Blade Question... #5
Well What I have given you is the creme of the crop so to speak. These threads I am familiar with and know that they contain information pertinent to your need.
Have fun.
Mike
Mike
Sounds like you have pretty much summed it up here in a short answer... also made note of locking down the rear blade for a better finish. Guess I will jsut need to get some seat time in lol
Thanks again.
UNUSED JCT 72" HYD ANGLE BROOM (A62131)
UNUSED JCT 72" HYD...
Gorman-Rupp T-Series Towable Pump (A61567)
Gorman-Rupp...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2026 Steel Pines Cargo 7x16 Enclosed Trailer, VIN# 7FWBE1622T1037829 (A61166)
2026 Steel Pines...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
