Box Scraper Box blade opp. Will it work for me?
   / Box blade opp. Will it work for me?
Yeah, I'm always looking for a deal.:D
I cut the bolts off that hold on the front blade this weekend. Underneath I found not so good news. All but two of the mounting holes were broken out at the bottom. Guess I'll have to weld in a piece of iron and redrill the holes.
Anyone know a good source for steel in the central Maryland area?
Also removed the spring assist contraption. Backblade on order. Disassembly now complete. On to getting ready to paint. No hurry, though. Long time till it's warm enough to paint.
   / Box blade opp. Will it work for me? #53
You could use a long handle on the lifting bar and blocks for it to set against for each position you want it to be at (and take the pressure off of holding it), then drill a hole for a hitch pin (or even simpler -- a Cat 1 pin).
For what it is worth, pay attention when using the BB when backing. It is a great way to bend your lower links. I usually used mine (5' 6" Economy on an old Case VAC) more as a smoothing blade by tilting the top link so that it was all that rode on the soil.
You will quickly find you need (want) top and tilt.
Now to find a 7'/8' one for Blueford.
Picked up new rear blade today: $88. Not bad :)
Then picked up some plow bolts: $87.60 for twelve with nuts. :(:(
Holy Crap! That's exspensive!
I ready to grind and blast off some rust. Just need some warmer weather. Come on spring!!!
   / Box blade opp. Will it work for me? #55
either I haven't priced them in a while or they saw you coming....
jb
   / Box blade opp. Will it work for me? #56
good lookin box and rippers!
soundguy
Finally! After many months, I got it refurbished. Just been busy.
   / Box blade opp. Will it work for me? #58
Looks like you did an excellent job. I hope that it holds up well for you.
Thanks for the follow up. ;)
   / Box blade opp. Will it work for me? #59
Beautiful job refurbishing! Does it work as good as it looks?
   / Box blade opp. Will it work for me? #60
Well done - I see that the Woods Hinged back blade fit very well.
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
2023 Kubota KX057-5 Compact Excavator (A55314)
2023 Kubota...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2019 Chevrolet Silverado 2500 4x4 Warner Service Truck (A55852)
2019 Chevrolet...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55314)
2020 New Holland...
2006 Ford F-650 Crew Cab Aluminum Landscape Dump Truck (A55852)
2006 Ford F-650...
