Box Blade on CT235
/ Box Blade on CT235 #1
Slowtorque
Cub Cadet 1782
Well, it's time to buy some tools for the machine so I can put her to work. I plan to buy a set of pallet forks, a box blade, a boom pole, and a toothbar. Should get me started moving mulch, grading my driveway, smoothing out the yard, and moving logs in the woods. Any recommendations on width of bb? Should I plan to cover the tracks and go with a 66" over a 60"? All will come from Everything Attachments.
/ Box Blade on CT235 #3
Sort of depends on your terrain. If you are going to have filled tires or not. No filled tires and hills = 5 footer in my book. Filled tires= 66 incher. I have a Mahindra 3215HST and I have a 66" roll-over box blade for it. I have some hills and my tractor will scrape and pull an over flowing load up hill. I feel that you should be able to pull a full load in what ever your worst requirements would be.
Just my opinion, others will vary. ;)
/ Box Blade on CT235 #4
I have a box blade on a 225, and a 60" covers the tracks. I think by about an inch on each side. You should have the power and weight to pull a 66" but I would not pay much more for it.
/ Box Blade on CT235 #5
Here we go:laughing: I just went through this just months ago. I went with a 66" BushHog RO like the one pictured in MtnViewRanch's avatar and a 5' Woods 500lb BB which I am selling I just like the 66" too much more has 2-3" over each side with no problem pulling material I have black clay in TX (I do not have filled tire either)If it starts to lose traction I just bring it up an little also I get to change ripping to grading by pulling a lever. The 60" is good but I think IMHO you can use the 66" you have 5hp more than me.
Just Remember Weight and a substantial side/back plate,*cross tube,3pt is your friend with the BB
Good luck in your purchase and enjoy
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
Bobcat 763 (A64126)
Bobcat 763 (A64126)
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
2001 Sterling Single Axle Dump Truck (A62613)
2001 Sterling...
UNUSED WOLVERINE MSG-11-44W STUMPLE GRAPPLE (A64281)
UNUSED WOLVERINE...
2011 New Holland HT154 Rake (A63688)
2011 New Holland...
