Dirt Moving Box Blade for JD 755
/ Box Blade for JD 755 #1
malwayne55
NC & MD
1986 JD 755 (MFWD, PS, HST, Loader).
I looking to purchase a box blade for the JD 755 (4 wd) and would like opinions on a 4 or 5 footer. Initially, I would be using it to change a garden back to a grass area, some light landscaping around the house after removing small trees/bushes and maintaining a long driveway. Thanks
/ Box Blade for JD 755 #3
I have a 5ft for my 855 and I feel like it is the right size. It really depends if you will use it more as a leveling blade or something that you will dig with.
/ Box Blade for JD 755 #4
I have a five foot box. I like it for the 500 pounds it provides for FEL counterweight. But there are times when cutting/leveling dirt and the box starts to fill it can seem like a four foot one might be better. Problem there is it would be more narrow than the tractor tires. If someone made a heavy duty four and one half foot one that could be ideal. So short answer is if you need the weight a five foot can be best, but if not a smaller one could work OK.
/ Box Blade for JD 755 #5
I have a four footer for my 790. The reason for a four footer is the use of it in the tree farm, where width issues come into play when in use in-between trees. Its a frontier BB2048 and a heavy, stout little thing it is.
So, working area should have some say with the size of the implement, only time I wish I had a wider box blade was leveling a larger area of about half acre or so.
For removing brush and small trees, I do not believe a wider box will be of advantage because of finding large and or many roots with even one ripper, its a hard pull, and just gets harder with more rippers down in my experience. But for driveway work and yard leveling, a wider box blade might be the way to go.
I would get a heavy duty box blade regardless of the width you choose also.
/ Box Blade for JD 755 #6
Good comments. I rarely if ever use all five rippers on mine for those reasons. Also times two on whatever size you buy, make sure it is a true heavy duty one. There are lots of lightweight ones out there for a cheap price. Spend the extra money for a good one. When comparing, weight can be your first clue.
/ Box Blade for JD 755 #7
This is generally true and I was going to buy a 5ft Woods for my 855 until I saw it and realized that it was too heavy duty for my tractor. The tractor supply (KK) is plenty heavy duty for a small tractor like mine in my opinion unless I run into something at high speed...which would also break some other parts I am sure...
For a 755 I would try to get a 54 on 60 inches medium duty. It is easier to level with a wider box. I would only consider narrower if I was going to dig a lot with it.
84in. Skid Steer Bucket (A65640)
84in. Skid Steer...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
