Grading Box Blade for B2910
/ Box Blade for B2910 #1
dlockh4258
Lexington Kentucky
Kubota B2910
I have a B2910 and was wanting to get a box blade for it. What size should I get. I have the B2910 with turf tires. I would like some input on which brand and what size would be the best for my trator. Thanks
/ Box Blade for B2910 #2
I think you would be well-served with a 5' boxblade. I would not go too much larger. A 5' will cover your wheel tracks.
How durable a boxblade to get depends on what you expect from it.
For example, I use mine to grade my driveway, and a neighbor's. I also use it for light landscaping work and, with the rippers all the way down, use it to rough "till" my garden. I would consider my use to be fairly light duty. Accordingly, I bought a locally produced boxblade that is approximately equivelant to the light duty models sold at Tractor Supply. These models can be had for about $350.
Heavier-duty models can be quite a bit more expensive, but the concensus here seems to be that they are definitely worth it if you need that kind of capability.
/ Box Blade for B2910 #3
If you look in your owners manual there should be a section where they detail all the major implements available and what size they recommend. I use a 5 footer on anL2500 and think you could probably use a 6 footer but maybe not with the turfs (I have ags). Too big is better than too small as you can always take a smaller bite if you start to spin. (Only an issue with the rippers down). As with most implements the heavier the better, I use an extra 250 lbs of steel weights on mine to help it bite better in hard dirt.
/ Box Blade for B2910 #4
David
I have a Land Pride BB1560 for my 2910. I do not have any problems using it with turf tires. I do need to use FWD for the best results.
/ Box Blade for B2910 #5
Try this post</font color=blue> "Boxblade price check and more..." under attachments.
I hope that works, I never did a link before.
I have a Woods HB60 on my B2910, but I really haven't had much chance to use it. Our ground is so hard that I figured I could use whatever extra weight I could. I have R4's on my tractor.
~Rick
/ Box Blade for B2910 #7
i use a 6' lienbech hd box on my 2910. it weighs in at about 500 lbs. it works great for greading the drive and some landscaping chores. i woudnt got any smaller but i do not work comercially with my machine.
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
58in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
58in Hydraulic...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
Mini Skid Steer (A60352)
Mini Skid Steer...
