3-Point Hitch Bouncing three point
/ Bouncing three point #1
mailman02
Carthage MO
ih
My Dk-35 three point bounces when raised with an implement attached. What is the problem?
/ Bouncing three point #2
Bouncing when driving?
Yes, in the up position. When I let it down, it is fine. Sitting in neutral with a six foot brush hog on, it will bounce the front tires
/ Bouncing three point #4
you have a loader on?
/ Bouncing three point #6
you need some front ballast.
Is there an adjustment on the draft control? The manual doesn't show anything.
/ Bouncing three point #8
yes same as the position control but you don't need that to cut.
Ballast can't be an issue be cause it will bounce when sitting still. It has been getting worse. When driving, you can feel it pulse. Also, it depends on which position the third link is in. In the lowest hole, it bounces slowly. In the top hole it bounces fast.
/ Bouncing three point #10
is your draft on?
What do you mean by on? Is it lever position? I usually run it in the down position as I have always done.
/ Bouncing three point #12
It seems your draft is stuck on.imo
/ Bouncing three point #13
The cylinder seal may be shot causing it to constantly drift down and correct itself.
/ Bouncing three point #14
How old is this machine?
/ Bouncing three point #16
raise 3 point with cutter on shut down tractor and post amount of time it takes to fall. Brad may be on to something
I will give that a try. Either cylinder seal or maybe in the valve?
/ Bouncing three point #18
Do you have somewhere to hook a chain up in place of the top link that does not pull on the draft sensing built into the normal top link mounting pin? Somewhere solid on the tractor. That would tell you if it is the draft control or not.
2012 Husqvarna YTH21K46 46in. Riding Lawn Mower (A64557)
2012 Husqvarna...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
Farm King 300-bushel Gravity Wagon (A66408)
Farm King...
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
Bush Hog 3-Pt Auger / Post Hole Digger (A66408)
Bush Hog 3-Pt...
