3-Point Hitch Bouncing 3Point - Jinma 354
/ Bouncing 3Point - Jinma 354 #1
cnsJohn
Lafayette, TN
Jinma 354
I changed the hydraulic fluid and filter on my 354; now the 3pt bounces. The arms drop a few inches and the bounce back up to their set position. Any ideas for a fix?
Your insight and experience are greatly appreciated.
JohnJ
/ Bouncing 3Point - Jinma 354 #2
Have you run it through several full cycles to purge any air in the system? Be sure to recheck fluid level afterword also.
Note: The only way you'll get a full cycle is to remove any implement and force the arms all the way down.
Thanks. I'm fixing to climb on it in a minute. I'll give it some cycles.
Thanks again for the suggestion.
CCWKen,
Seems no amount of lift arm cycling, without or with implement, has solved the bouncing issue. Any thoughts as to what else might be causing the problem?
2002 Harmon Steel Barrel 7,000 Gallon Asphalt T/A Tanker Trailer (A68183)
2002 Harmon Steel...
XTREME XR1147 TELESCOPIC FORKLIFT (A65056)
XTREME XR1147...
2016 Nissan Pathfinder 4X4 SUV (A66738)
2016 Nissan...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
1991 American Pride APE2-6 Electric Cart (A66738)
1991 American...
