3-Point Hitch Bouncing 3Point - Jinma 354
/ Bouncing 3Point - Jinma 354 #1
cnsJohn
Lafayette, TN
Jinma 354
I changed the hydraulic fluid and filter on my 354; now the 3pt bounces. The arms drop a few inches and the bounce back up to their set position. Any ideas for a fix?
Your insight and experience are greatly appreciated.
JohnJ
/ Bouncing 3Point - Jinma 354 #2
Have you run it through several full cycles to purge any air in the system? Be sure to recheck fluid level afterword also.
Note: The only way you'll get a full cycle is to remove any implement and force the arms all the way down.
Thanks. I'm fixing to climb on it in a minute. I'll give it some cycles.
Thanks again for the suggestion.
CCWKen,
Seems no amount of lift arm cycling, without or with implement, has solved the bouncing issue. Any thoughts as to what else might be causing the problem?
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
