3-Point Hitch Bouncing 3Point - Jinma 354
   / Bouncing 3Point - Jinma 354 #1
cnsJohn
Bronze Member
Lafayette, TN
Jinma 354
I changed the hydraulic fluid and filter on my 354; now the 3pt bounces. The arms drop a few inches and the bounce back up to their set position. Any ideas for a fix?
Your insight and experience are greatly appreciated.
JohnJ
   / Bouncing 3Point - Jinma 354 #2
Have you run it through several full cycles to purge any air in the system? Be sure to recheck fluid level afterword also.
Note: The only way you'll get a full cycle is to remove any implement and force the arms all the way down.
Thanks. I'm fixing to climb on it in a minute. I'll give it some cycles.
Thanks again for the suggestion.
CCWKen,
Seems no amount of lift arm cycling, without or with implement, has solved the bouncing issue. Any thoughts as to what else might be causing the problem?
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
2013 Chevrolet Tahoe SUV (A49461)
2013 Chevrolet...
71053 (A49346)
71053 (A49346)
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
