Bought new pickup should I get it undercoated ?
   / Bought new pickup should I get it undercoated ? #21
Yes the body has been made of mostly aluminum since 2015 but the frame is still made with mostly steel.
Aluminum corrodes nearly as bad as steel with road salt.
If you live in the rust belt get it under coated with something like fluid film, wool wax or NH oil undercoating.
I'm a former municipality fleet mechanic and no amount of washing can keep the rust totally at bay.
   / Bought new pickup should I get it undercoated ? #22
That is very true .
My best friend bought a 55 gallon drum years ago and built an application pit .
All our vehicles get treated twice a year .
We feel that it has been a very good return on investment .
   / Bought new pickup should I get it undercoated ? #23
I am a fan of Krown rustproofing once a year.
It is inexpensive, after the first 2 weeks it is not near as nasty and messy as Fluid Film and other thick bodied types.
Krown is a Canada based company and if you read forums you will find Canadians who totally swear by it.
For $169 a year, you can't beat it.
   / Bought new pickup should I get it undercoated ? #24
I'm a fan of any of the oil/lanolin based coatings. Just did a pre-treatment of the rockers and frame of my new truck with Fluid Film and NH Oil Undercoating materials.
I'd like to play with the Krown products too, just haven't gotten around to it.
One thing I have noticed is that over time, the protected areas look good (well, oily and grimy, but not rusty) but it seems like areas that are not treated rust more. My 2012 looked pretty good until I found some areas that I did not treat. Weird places like the seat brackets. They would never had even gotten wet, much less coating in salt spray.
I'm a fan of washing regularly too, but I'm leary of the automatic car washes. They recycle the water, so the high pressure wash cycle sprays salty water at high velocity at your rig. Are the do-it-yourself wash stations any better? Wish I had a hot water set-up at home.
   / Bought new pickup should I get it undercoated ? #25
My father had a Ford Mondeo of which the underside of the doors rusted, from the inside out. Ford cut some costs on hollow space protection, so i brushed it off every year and brushed some bitumen paint on it, which was as black as the cars paint. Ford had serious rust issues with the 3rd gen Mondeo, which is why they were cheap.
Within 2 years from new, Ford dealers would recall these cars for a hollow space coating, but for this one it was already too late, the rust was already in the seam and kept pushing from within.
So if you undercoat a vehicle, do it when the vehicle is absolutely dry, to not include moisture between the layers.
And when the coat dries out and gets brittle, soften it by spraying some used gear oil on the underside so it doesnt dry crack.
And after welding the door sills of my sister in laws Daihatsu, we poured used oil in them and parked it a few hours in front of the muck heap to drip out, before returning it to her on the clean pavement. Just like English cars: they dont rust where they leak.
   / Bought new pickup should I get it undercoated ? #26
Living in Minnesota. I buy a new vehicle about every four years for my wife and me. She gets the new truck and I take her four-year-old truck. So, we keep them for 8 years with about 150k-170k miles on them. No undercoat and have never had a rust problem on them. Been doing this for 30 years. I wonder sometimes, if me keeping the vehicle from years 5-8, and keeping them outside in the winter, not allowing them to thaw and re-freeze helps keep them better. I'm about to find out as our new home now has a heated garage we can keep them in through the winters. They will now have much more moisture on them through the winters.
   / Bought new pickup should I get it undercoated ? #27
yeah, it's weird how it works ... I know some vehicles are more prone to rust then others, 8 years is enough time to get rusty, maybe not enough to rust right out but enough to get some surface rust under de vehicle ...
   / Bought new pickup should I get it undercoated ? #28
I see people saying the aluminum will rust. Aluminum won’t rust although in theory it can corrode. I belong to an F150 forum and so far I have not heard of a single case of an F150 having any issues with the aluminum parts corroding. I have seen people ***** about how rusty some of the steel parts are rusty underneath on brand new trucks. They have been making the aluminum body’s since 2015 so that’s going on 8 years now.
   / Bought new pickup should I get it undercoated ? #29
Maybe rust was the wrong word. But when I was having my truck rockers and cab corners repaired... There was an aluminum bed Ford in the body shop for repair. Rust/corrosion, I don't know which. But it was no longer looking 'factory fresh' so to speak. My area gets a lot of pre treatment for expected bad weather though...
   / Bought new pickup should I get it undercoated ? #30
I grew up 10 miles from Minnesota. Y'all use a boatload of salt. If they are not rusting in Minny, they won't rust elsewhere. Older vehicles may be a lot different, anyone adding rustproofing to a new car is throwing away cash.
   / Bought new pickup should I get it undercoated ? #31
Depends upon how long you want to keep your truck I guess. In Canada in the warmer eastern provinces if you spray a rust inhibiting oil like Krown, Fluid Film or Rust Check under your vehicles and inside door panels every fall before the salt appears on the road you can keep your vehicles rust free indefinitely. It is worth the $130 per vehicle when you consider what a new one costs.
   / Bought new pickup should I get it undercoated ? #32
They spray a mix of calcium chloride on the roads here in the winter as a pre treatment I believe. I could be very well be incorrect, but sounds right...
   / Bought new pickup should I get it undercoated ? #33
I’d like to have seen pictures of that. I’m not doubting you, it’s just something that is very uncommon. Someone comes on the F150 forum asking now and then about any corrosion issues with the aluminum F150’s and I have yet to see or hear of one.
   / Bought new pickup should I get it undercoated ? #34
I wouldn't say indefinitely, but it does add several years to a vehicle's life.
   / Bought new pickup should I get it undercoated ? #35
Are you asking to see a picture of the corrosion/rust? I wish I could, but it was 5 years ago I had my truck fixed I bet.
I'm just going off what the body shop guy said when I made the comment..."wish my truck was aluminum so I didn't have these issues.". Then he showed me a Ford with the issue.
I could be wrong, or that truck could have lived a harsh life, or anything in between. I was surprised at the conversation as well. I don't want to spread false info. So if I'm wrong, I'm wrong. Lol
Got $500 worth of free Ford accessories with the deal so today I bought a Ford roll up Tonneau cover, that took the entire $500 , also bought some other brand floor mat for the box that cost another $200. Might also buy some kind of floor mat for the driver, all this stuff sure adds up quickly !
   / Bought new pickup should I get it undercoated ? #37
I subscribe to the do it when new, or don't do it at all school of thought. When I got my last new vehicle - a 93 Dodge van, I drove from the dealership to Ziebart and had it undercoated. Thirty years later, just a little rust out around the rear wheels.
Today, I'd do it myself. The link below is to Cosmoline - been making rust preventives since WWII. The specific link is manufactured to military specs, but is not certified. I think they're a company to be trusted.
   / Bought new pickup should I get it undercoated ? #38
if you don’t miss a single year i agree with him at 100%. You will go through the engine, the tyranny and everything else and the body will still be rust free …
   / Bought new pickup should I get it undercoated ? #39
2022 Ford F-150 extended cab. Would love to hear some of your opinions-experience about undercoating. Living in Wisconsin rust is a really big issue.
I’m definitely not a high miles driver and at 68 years old this could be my last new truck.
I have all of my vehicles sprayed with Krown rust proofing .
   / Bought new pickup should I get it undercoated ? #40
In Spokane and at major intersections the county/city sprays some type of liquid ice melter. I will leave thawed stripes on the ice covered roads. I avoid Spokane in the winter.
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
John Deere 25A Flail Mower Tractor Attachment (A59228)
John Deere 25A...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
