Botazilla is Born!!
/ Botazilla is Born!!
Kubzilla-
Yeah, come to think of it that may be the best way to go. And it would be a lot cheaper than buying a stand-alone grapple. Even Frits (a.k.a. m7040) put a grapple arm on his M7040 bucket. I know 3RRL put two on his bucket but if I were you I'd just put one. (3RRL has a great setup with a bucket and toothbar with two grapple arms; he also has a top 'n' tilt on the rear.) It probably wouldn't add that much weight and would make the bucket infinitely more versatile and useful. Check out "The Thumb". They also sell quite a bit on ebay. You WOULD have to measure and see what size you would need and would probably need to weld a piece of steel on the upper lip of the bucket for reinforcement. But, all-in-all, it would probably be well under $700 total for everything including hydraulic hoses and connectors. If you don't already have a toothbar on your bucket you may need to look into that as well. A bucket alone is good. A bucket with a toothbar is better. A bucket with a grapple is great. A bucket with a toothbar AND grapple is AWESOME!!
/ Botazilla is Born!! #43
Sweet Pics Glowplug. That's one tough looking tractor you have there! I have tractor envy!
Podunk
/ Botazilla is Born!! #44
Yikes, I may have to sic our L-39 TLB Space Alien on Botazilla!!! :D
Whoa.:eek: That's intense. Looks like it's straight out of a sci-fi movie. Your space alien looks intimidating; could probably take Botazilla on the intimidation factor alone!
/ Botazilla is Born!! #46
Glowplug said:
Kubzilla-
Yeah, come to think of it that may be the best way to go. And it would be a lot cheaper than buying a stand-alone grapple. Even Frits (a.k.a. m7040) put a grapple arm on his M7040 bucket. I know 3RRL put two on his bucket but if I were you I'd just put one. (3RRL has a great setup with a bucket and toothbar with two grapple arms; he also has a top 'n' tilt on the rear.) It probably wouldn't add that much weight and would make the bucket infinitely more versatile and useful. Check out "The Thumb". A bucket with a toothbar AND grapple is AWESOME!!
I think that the Thumb would work perfectly for my setup!:D I appreciate all the responses...Mike
Don't forget to consider how you will control the grapple. The only downside to using a grapple arm like 'The Thumb' is that in theory the bucket sides could potentially limit grabbing a large amount of wide brush. But you should be able to "crush" it down into the bucket. One advantage is that you could carry individual items easier such as small tree trunks using the sides of the bucket for support. Good luck!!
/ Botazilla is Born!! #48
Man, there has been many times I wish I had one of those. This past fall being one of them as I cleared 7 acers of stone walls of trees and brush and had many great fires. That would save a lot on my back hauling it to the fire. The big problem is justification as I wouldn't use it enough to get any kind of pay back. :)
/ Botazilla is Born!! #49
Pay back? You could write it off against the entertainment fund! How about adding a 4n1 bucket to the the new B26 that you ordered ? Grapple, doze, dig, dump, etc....Still pricey, but may be easier to sneak in the door :)
You know it!! I'm not in it to make money or even SAVE money for that matter. Some people buy fancy sports cars; some go on fancy vacation cruises; some eat out at 5-star restaurants. Me? I play with my tractor and move big things with my grapple!!:D ;)
Here's a couple of pics of Botazilla moving some logs.
May be a little dark. The sun was getting ready to set.
The second picture is actually the better of the two.
/ Botazilla is Born!! #51
Yea, I understand. My mid-life crisis is deciding between the new Yanmar CBL-40 or a new ASV100 :)
Well I finally got that big stump carried off!! I DID have to saw it up a little bit. I don't know if I could've lifted it or not in its entirety based on its weight but it was really huge and bulky. Here are some pictures. . . .
BTW, it helped to have the two separate cylinders with grapple arms in this case due to the irregular shape of the stump. Sorry about the second pic. You may have to lie down to see it correctly.:eek:
/ Botazilla is Born!! #53
Nice job on the stump. I love the smell of grapples in the morning.:cool:
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
2022 EZ-GO ELITE...
Sakai SW354 (A64126)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
