Boring out pin holes
   / Boring out pin holes #1
enterprisebbc
Ct
2008 CK35 Kioti
Can someone tell me if its ok to bore out the pin holes in an angle snow plow cylinder? I have an old Jeep plow 6' with 1.5, 10" that have a 1" pin hole. Now all I can find thats not to much $ is the same with a 5/8 pin hole. Or I can weld a cpuple of washers on the plow to accept the smaller pins. I have found exact replacement with the 1" but they are $100 apiece. Any ideas? What would you do?
   / Boring out pin holes #2
If you are talking about reducing sleeves for the pin hoes, TSC has adapter sleeve to reduce the pin hole, or make your own.
Is that Tractor Supply?
   / Boring out pin holes #5
I would try boring the cylinder holes. You may find the cylinder rod is hardened and can't be drilled, if so I would bush the snow plow mounts for a smaller pin.
I think welding washers on would not be enough support and quickly wear out.
SCAN FOR HAULING AND FINANCING INFORMATION (A54756)
SCAN FOR HAULING...
LOT LOCATIONS (A54607)
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
