Boosting question.
/ Boosting question. #31
Ive always replaced both at same times also.
So definitely the battery was the issue, it was bulged quite a bit and frozen solid, the mechanic replaced it and the tractor fires right up easily and now recognizes when a booster is installed (you can see the voltage change)
/ Boosting question. #33
On my NOCO GB150, I have to hit an override function if the battery I'm jumping is too low. You might see if that's your issue.
/ Boosting question. #34
Just a note: frozen batteries can explode when boosted.
/ Boosting question. #35
Hello I have a question about boosting that no one in my area can’t seem to have an answer about. My tractor is dead and it’s really cold outside so it needs a boost.
I have several high end booster backs that can start a dead semi and I have my ram 3500 to boost from, but no matter that I hook up to either my tractors boosting post or straight to battery the tractor won’t start, it’s like the tractor wasn’t even hooked up to anything. The weird thing is I had a dead battery on my truck once and it too acted like I never had a booster hooked up to it.
Logic says that what I hook up to the tractor is now the new starting battery so it should fire right up (especially using the truck to boost it) but it still won’t boost.
Can anyone please explain this to me and why that logic isn’t working and what I can do to get it boosted. Thank you.
Have you cleaned the terminals? Spent an hour helping a guy try to start his boat and he insisted the terminals were clean. I finally said just humor me and remove the clamps and scrape them with a knife which was all that was available so he did. Reconnected them and it started very nicely. They looked perfectly clean but as it turned out not so much.
/ Boosting question. #36
This is gonna sound absurd, but it's not an old (antique) style tractor with reverse polarity is it?
A couple young lads wanted to borrow my dad's old farmal cub a few years ago and tried jump starting it like a normal car or newer tractor with negative ground. They never got it going and just fried the voltage regulator. I never understood why the old tractors were wired positive ground. Musta been a British thing.
Good luck. Try to stay warm.
/ Boosting question. #37
Try to dismabtle de battery cable then charge with the booster battery with the 2 cables m dismantled. The battery is too low so it jump and cancell the starting process. My F-150 pick up just did the same lately.
/ Boosting question. #38
Read the whole thread before posting. It got it fixed, before Christmas...
  • Good Post
Reactions: HAR
/ Boosting question. #39
It sounds like your battery is fudged.
Every time your battery is discharged and re-charged, electrons are moving from the electrolyte to the lead and zinc plates in the battery. That process is not perfect, and each time electricity moves, a small amount of sulphate (basically a salt crystal) is deposited on the plates. The "deeper" the discharge, the more salt crystals accumulate on the plates. When your battery is at 100% charge and you hit the key and pull several hundred amps through the starter, and even though the engine starts in a few seconds, the battery is discharged down to say 95%. A few minutes of operation and the alternator replenishes that 5% charge that had been drawn off. A normal battery, starter, and charging system will go through a few thousand of these cycles before that sulpation salt accumulation occurs.
Everything changes at 40 below. Chemical reaction in the battery is vastly slowed, and instead of 100% down to 95% during a start cycle, its 100% down to 50%. Sulphation and battery performance degradation occurs much faster.
And if a battery goes down to say 5% charge, the electrolyte will freeze, swell, and break the plates inside the battery loose from their mounts, and possibly short them against one another. That probably won't happen across the whole battery, but just one cell, and the sign of that is one (of the six) cells or segments in a battery getting hot while on the charger or hooked to a boost.
When hooking up the booster cables the dead-battery unit should be hooked up first, its that dead battery that is taking and giving up a charge, and in doing so is "gassing off" potentially explosive gas. All sparking and arcing should be done far away from that. Have the booster vehicle running, with low electrical load in that vehicle (heater fan on low, lights off, heated seats and rear window defogger off) so that the alternator in the booster vehicle does not get over-jolted. The last of the connections to make is the negative cable to the booster vehicle, preferrably to a bare-metal part of the engine or frame brace.
As the last connection is made, observe the size of the "connection spark". If its full-on welding, you probably have the cables backwards, check and re-check. A small spark is normal. No spark probably means your battery is "not taking a charge" and is fudged.
Allow the booster connection to charge the dead-battery for a few minutes before attempting to start. Remember that the booster cables are connecting with just a tiny point of copper to the battery cable or frame brace, and that tiny point of copper can only carry maybe 50 amps. And that presumes your booster cables are actually copper, not some mystery-metal plated with copper-like substance. The point is the cable from the battery to the solenoid to your starter is thick conductive copper, the connections are ring connectors under big bolts, and the ground is certain. Connected booster cables and those tiny connection points have a hard time carrying the several hundred amps of current needed to spin over that 6140 at 40 below.
If the tractor is computerized - I think a 6140 is - a battery not taking a charge is dangerous to boost. You hook up cables to booster vehicle, and system voltage is above computer-operating voltage of ~10 volts, the computer turns on, boots up, and tries to run the engine and the tractor. Then you hit crank and connect several hundred amps of starter load, those tiny booster cable connection points heat up and smoke and stop conducting, and voltage drops and computer shuts off. With computer off, starter goes off, voltage goes up computer comes on, etc. This on-off-on-off scenario is not good for that tractor computer, and computer smoke is possible if not likely.
You do not want to find out the cost of computer smoke on your 6140.
Put in a new battery.
/ Boosting question. #40
Yes, I turned it over and it cranked then slowed down as the battery lost its charge. The ground did have corrosion but I got it all cleaned up.
I checked all the fuses and fusible links and relays and all are good.
Removing 2 bolts and I can get access to my starter, I’ve never boosted off of a starter so I’m not sure how it works and what the connections are. The John Deere mechanic managed to boost it via the starter but I wasn’t around when he did it so I couldn’t see what he did.
Possibly a 2 person job as someone has likely to sit on the seat, press brake, (emerg. brake off) give it some fuel (depending on make and model, pulling the shutoff disconnects pump and electrical I believe)
while the other person takes the + lead and does a quick clamp to the big post from the battery on the starter. This bypasses the Solenoid and safety switches.
2019 Bomag BW 211D-5 Single Drum Vibratory Soil Compactor (A59228)
2019 Bomag BW...
KSI Conveyor (A61307)
2014 Nissan Murano SUV (A59231)
2014 Nissan Murano...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2001 Freightliner MB55 Bus (A59230)
2001 Freightliner...
