Boom pole
/ Boom pole #1
Gizmo36
Platinum Member
East of Duewest S.C.
Will a Boom Pole for a 3 point hitch on a YM1700 or 2210 get hight enough to put a motor out of a small car. has any one ever tried this.
/ Boom pole #2
Yes. I do this all the time. To get the extra height if you need it, just shorten the top link.
Eugene
/ Boom pole
Thank you , My son wants to pull a motor . I found a Boom pole for $50 . I told him to pay 25 and i would . He said he did not think it would lift hight enough to do it.So i will add one to the stock pile.I have not heard from Claude yet .When i do i will let you know.
/ Boom pole #4
If you hook right to the end and use a short toplink.. I'd think you can have about 8' or so of lift. mind you.. the weight is multiplied.. so when pulling a heavy load.. keep an eye ont he tractor front end... Might have to ballast it... etc.
Soundguy
/ Boom pole #5
I made my own, it will lift 18 feet and about 400 pounds, be careful on the weight as the others are saying and balance. A work platform is next for pole for reaching heights. Better than a ladder
Jim
/ Boom pole
MrJimi I like that , Now that is getting up there.Soundguy if i can get it to go up 8 feet that would work.
/ Boom pole #7
Its only a piece of 3" schedule 40 pipe bolted to a backing plate. It picks the forks up but when I tried to lift the back of my Chevy S-10, the pipe bent? Oh well I got silly and it did not work, I made this to lift about 200 pounds and it does that well, thanks on compliment
Jim
Water Pump with Engine (A65640)
Water Pump with...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
Skid Steer Hydraulic Adjusting Forks (A65640)
Skid Steer...
1995 Landoll Trailer, VIN # 1LH17AUHXS1007250 (A65563)
1995 Landoll...
2013 KENWORTH T800 WINCH TRUCK (INOPERABLE) (A65643)
2013 KENWORTH T800...
