Boom pin for 331 excavator
/ Boom pin for 331 excavator #1
Lakeside Doug
Bobcat 331 excavator
Can you use a piece of cold roll steel for swing bracket to boom cylinder pin? Or is it made of something special and must use the factory pin?
/ Boom pin for 331 excavator #2
cold rolled is soft and not great material, I have made lots of pins and get material from the local cylinder rebuild shop, the hydraulic cylinder rods are good material and they usually have lots from old cylinders for decent price, its easy to machine with carbides
/ Boom pin for 331 excavator #3
I've made some bucket pins out of stressproof rod , works fine. Laurencen idea excellent too
/ Boom pin for 331 excavator #4
You "can" but the problem is its soft and weak. Ever try and remove a bent pin from a excavator.....not fun.
There are a whole lot of materials suitable. 1144 stressproof, 4140 or 4340 are excellent choices.
Usually pins are pretty hard. Like upper 50's or lower 60's on the Rc scale. Thats more for wear than strength. Sounds like you are talking about a pin for the slew cylinder.....so a non-heat treated pin wouldnt concern me as much as a pin on the main boom. Because the slew cylinder usually sees a fraction of the use the other pins do. But it still needs to be strong because its under alot of force as it has to hold the boom straight when digging
