Boom Gouge
/ Boom Gouge #1
bindian
Super Member
Willis, Texas
Mahindra 6520 4WD
I gouged the side of the boom, when I had to upright it with my loader bucket. Post #38 https://www.tractorbynet.com/forums/projects/398806-project-i-had-not-planned-4.html?highlight= It is about a 10th of an inch deep. Should I blend out the gouge and weld a bead over it, or just blend it out, or just ignore it? 9-21-18 CAT Boom Gouge.jpg9-21-18 CAT Boom Gouge Closeup.jpg9-21-18 CAT Boom Gouge REAL Close.jpg
hugs, Brandi
/ Boom Gouge #2
I would blend it out but I guess a lot of people would just ignore it.
/ Boom Gouge #3
I would at minimum, take a sanding disc and remove the sharp edges and repaint it. Weld it up if you want to, but it really isn't hurting the structural integrity at this point.
BTW: while sanding and painting, just sand that rust scab plate and paint it also.
/ Boom Gouge
Gary,
That rust scab plate is the light mount hole. The bolt is sheared off and still in there. I tried twice to weld a nut on, but it wouldn't hold. I drilled it out and put an easy out in the hole and used the impact to remove the bolt. It is sanded and painted now.
hugs, Brandi
/ Boom Gouge #5
That's not even worth burning the paint. If you have touchup just cover it.
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
2020 Kenworth T680 Semi Truck, VIN # 1XKYDP9X1LJ302478 (A61165)
2020 Kenworth T680...
All-Aluminum Timpte 720 Trailer (A63118)
All-Aluminum...
2017 International HX620 Quint Dump (A62613)
2017 International...
STORAGE FEES (A59909)
UNUSED CFG INDUSTRIAL QK16R MINI EXCAVATOR (A62130)
UNUSED CFG...
