Bolt on tie downs
/ Bolt on tie downs #1
jigs_n_fixtures
Salmon, Idaho
TYM T293 CAB, & T233
Does anyone know of a manufacturer of bolt on tie down points for TYM tractors?
I chock the wheels, and then chain down the axles on my T233 and T293 when I need to trailer them, but it would be easier to tie it down if there were bolt on chain points, which bolt to the frame and have pressed out chain eye holes on the ends of the frame rails.
I've seen bolt on units for other brands on YouTube. just wondering if anyone knows of a source?
/ Bolt on tie downs #2
/ Bolt on tie downs #3
I just wrap a chain around each front corner of the tractor frame for the front tie downs, and run chains out to the back corner tie downs off of a straight clevis hitch on my draw bar in back. Binders on each corner. Don't need any "hooks". Works fine for me.
/ Bolt on tie downs #4
I replaced two of the bolts on the front frame with eyebolts. These bolts are threaded through the frame so I installed threaded bolts that were longer and I added a washer and nut to make sure they held. I use the eyebolt to tiedown the front of the tractor when I trailer it.
The picture shows which bolts I replaced, I never took a picture of the upgrade.
/ Bolt on tie downs #6
Im not sure of the shear strength of a bolt on device to hold back a tractor…especially a tractor hooked to a trailer that is involved in going from 60mph to 0mph in a matter of seconds….. think crash
/ Bolt on tie downs
The majority of frame connections on the T233 and T293, are bolted. And depending on what steel, at what heat treatment that steel has, bolts are better than welding, if you don’t have the ability to stress relieve the welds and re-heat treat the steel.
So, I would rather stay with bolted connections like the factory engineers did. The strength of bolted connections is pretty much dependent on the quantity, grade and size of the bolts.
/ Bolt on tie downs
Thanks, for the input guys. The tie downs from Bolt on Hooks, look idea but are out of stock. I put my info on their wait list.
I found some bolt on D-Ring anchors with 12,000-lbs ratings, so a working load of 4000-lbs. But the bolt spacing isn’t quite right. Looking at possibly buying some weld on D-Ring anchors, and getting them welded onto some 3/8-inch plate with the holes drilled to match existing holes in the frame.
Case International 21' Disc Harrow (A64127)
Case International...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
1992 International 8200 Spreader Truck, VIN # 1HSHEDPN2NH418329 (A65563)
1992 International...
SKID STEER AUGER ATTACHMENT (A62613)
SKID STEER AUGER...
