Bolens Kohler engine problem
/ Bolens Kohler engine problem #1
Anonymous Poster
Epic Contributor
I have a Bolens HT-20 with a Kohler engine that has the strangest oil pressure problem. When the engine is cold the pressure is 50#. When the engine warms up and is at full throttle it drops to 25#. If I then return the hot engine to idle the oil pressure goes back up to 50#. Normally a slow running engine would have lower pressure and the pressure would increase with the higher RPM. It is a mechanical gauge with a tube. Changed oil to premium 30 wt and put on a new Kohler oil filter and nothing changes. What is wrong? or is just a fluke of the Kohler engines? It is a Kohler model 532 engine. thanks
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
Lot 602 (A62613)
Lot 602 (A62613)
