Boiling Fuel
   / Boiling Fuel #1
Digger 258
Northern VA
Bolens / Iseki G152 & PT-425
Mowed for about an hour in 85 degrees and when I parked to move the trampoline, I heard a hissing from the fuel tank cap (it's a steel tank in the lid, with a steel cap). When I peered into the tank the gas was at a full boil. I was hesitant to continue mowing after that, so I waited an hour and searched the forum in an attempt to smooth out my fears - hoping to find that "everyone's gas boils, this is normal!"
I read about wrapping or re-routing fuel lines (not sure I can) and new fuel filter (tomorrow's plan), but other than that, should I be concerned? I rebuilt the carb a few months back thinking I was running lean when my exhaust and expanded metal in front of the exhaust were glowing red hot at night, but I'm not sure it's running any cooler now.
Not sure if it's even safe to use, since boiling gasoline just seems wrong . . . I appreciate your thoughts/experience.
Regards
   / Boiling Fuel #2
If it was truly boiling it hit 180degF! May want to check that the tank is insulated from the heat source.
   / Boiling Fuel #3
I had problems with that.
My ultimate solution was to remove the fuel pump from its mount one the left cylinder head (close enough that heat radiating from the exhaust cooks it) and mount it on the left side of the engine compartment. Also put silver thermal sleeving over the fuel hose where it passes near the exhaust manifold.
The mechanical fuel pump is driven from impulse pressure through a 1/4" tube connected to the crankcase, so you can relocate the fuel pump wherever you want it.
After having my second fuel pump go bad, I recently replaced the mechanical fuel pump with an electrical fuel pump and am happy with the results.
   / Boiling Fuel #4
Holy Crap! Was it sitting in the sun? What make is the mower? How hot was the fuel? Some components of gasoline vaporize off at fairly low temperatures.
   / Boiling Fuel
I was indeed mowing in the sun, and the gas was at a full boil when I stopped. Thanks for the tips Tmarks, I'll find some thermal sleeving and re-route the fuel pump and see what that gets me. I thought about putting another fan in the side of the lid, but then again, maybe I'd be just covering up what is the real cause, the engine running too hot.
   / Boiling Fuel #6
I'm assuming you are running the 425 with the stock PT exhaust? If so, I would suggest you search the threads for the installation/mod of installing the Robin muffler along with an additional side exhaust fan. I still get a little bubbling at he bottom of my fuel tank but it's certainly not boiling.
The exhaust mod drastically reduced my tub temps. I also insulated my fuel line and one of these days I need to relocate the pump too.
   / Boiling Fuel #7
I would say not! Definitely not under that condition. Boiling gasoline? You were virtually sitting on a BOMB. With the vapors being released, you were very, very fortunate they didn't ignite on that glowing red hot metal or when you opened the gas cap to peek in. :eek:
I wouldn't continue to press your luck.
   / Boiling Fuel #8
My subaru engine didn't last long enough for me to see that on the PT 425, but I've experienced it on another machine. And I got proactive w the PT once I realized how spectacularly hot the pipe was.
That exhaust definitely needs shielding...the tank could use it too. I applied a thin sheet of aluminum to each side of the steel heat shield vertical and underneath separated by a few washers as spacers.
Make sure the gas cap is venting properly (air comp clean) excess pressure in the tank can add to the problem, and is dangerous when you can't resist peeking...
I found that the oil cooler fan did a pretty good job clearing heat from the tub...but aluminum and an air gap did much better.
   / Boiling Fuel #9
...excess pressure in the tank can add to the problem, and is dangerous when you can't resist peeking...
+++1
DAMHIKT!
   / Boiling Fuel
I have an older PT-425 with the Kohler engine. Here you can see the PT exhaust, wrapped in a cloth heat shield I presume from PT. My tank is steel, and incorporated into the lid, with a steel gas cap. The fuel lines don't run near the exhaust, but I'm sure they get hot none-the-less. I also mounted a tool box to the top of my tank, which might be contributing to the boiling fuel. Is there a different exhaust set up for the Kohler I should be looking into to run cooler? DSC_0500.JPGDSC_0685.JPGDSC_0686.JPGDSC_0687.JPG
I've got heat tube on order and I'm looking into how I might mount the fuel pump. Thanks for all of the input.
Regards
   / Boiling Fuel #12
You should be able to buy a Kohler exhaust manifold that fits your engine that will let you mount the muffler outside the engine tub. That will help quite a bit.
   / Boiling Fuel #13
Digger,
I was just reading about a David Brown tractor with boiling gasoline, back in the day, and thought about your problem. Did you solve it? I'd like to hear the end of the story.
   / Boiling Fuel #14
I flew a twin engine Beechcraft B55 on a short flight that had to cross 11,000 ft Sierra Nevada peaks along the way. So, in just a short distance from takeoff to landing it was a maximum performance takeoff and maximum performance climb up to 12,500 ft to cross. The pilot handbook calls for low boost setting on fuel pressure for takeoff then turn off the boost after climbing 1,000 ft. I did that.
At 12,000 feet while still climbing the right engine quit ... ahhhh! I could not restart the engine. I was at the crest of the mountains and was able to limp my way to the other side, half under power and also sort of gliding while working on why the engine quit. A B55 cannot hold at that altitude on only one engine. Eventually I got the engine restarted. There was nothing in the pilot operating handbook or any published procedure about what to do in this condition. I believed my ability to restart it was somehow connected to getting to a lower altitude.
Later, I talked to friends and mechanics, describing what had happened. They all said: "oh, turn the fuel pump to high boost because the heat from maximum climb boiled the fuel in the lines." I said that was not in the pilot's operating handbook. Their reply: "Everyone knows that ....."
Apparently it was cold enough outside and with the engine shut down my later restart effort allowed fuel to flow again .... live and learn.
   / Boiling Fuel #16
See, that's the beauty of tractors VS airplanes.... you just pull over and park when the engine quits. ;)
   / Boiling Fuel #18
Well, in the A-team movie they flew a tank firing rounds in various directions to steer as it descended ... after the aircraft ferrying it was shot to pieces.
   / Boiling Fuel #19
Digger doesn't seem to be around. I guess I'll have to hope Paul Harvey tells me the rest of the story. Come to think of it, I don't remember seeing a post from him lately, either.
   / Boiling Fuel
Sorry, I was overseas for a bit, which reminds me once again how much I'm looking forward to retiring and taking a more pedestrian job...
I ended up cleaning the tub really good, hoping the gunk built up on the tank was part of the problem. I also put heat shield on the fuel lines. I don't seem to have the boiling fuel problems anymore, but I haven't mowed in the heat yet either. My exhaust still glows cherry red at night, which has me concerned. So, I guess I'm not sure if I fixed it and I'm still concerned with the exhaust heat. I won't refuel it when she's hot anymore, since I nearly burned it to the ground once doing that. Wish I could figure out if I'm running too lean, causing all this heat, or if it's just normal. Sorry I don't have a better answer, SM. Cheers
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
VOLVO A25G OFF ROAD DUMP TRUCK (A60429)
VOLVO A25G OFF...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
