Bobcat M700 Drive Problems...
/ Bobcat M700 Drive Problems... #1
miking1834
Bobcat M700
I have a M700 and it has drive problems.
The bucket works great so I do not think it is the vane pump but maybe just the drive pump is wore.
On gravel it steers fairly well. But on asphault it has a terrible time trying to turn. You can hear, I believe the pump load up and it really struggles, especially once the oil warms up.
Goes forward and backards fine. But if you have a large load in the bucket and you try to go up a steep grade it also does not like it.
I do not want to buy a pump if that isn't the problem though, any help would be much appreciated.
Thanks,
Michael King
/ Bobcat M700 Drive Problems... #2
They don't like pavement for turning, especially if you have good tires. Does it have good power going in straight lines, no tendency to wander to one side? Spin the tires when you push against a big tree or other immovable object? Mine likes to hop around on pavement and groan a bit in protest, I just make shallower turns or back and forth it a bit. Kind of used to that anyway to avoid tearing up the lawn.
It goes fairly straight. It won't spin the tires when pushed up against something.
It groans real loud just like when your trying to get it to turn on dry concrete.
I just pulled the cage off today so I can try and get this figured out. I am thinking maybe it is stuck in "High Range". The speed linkage looks a little sloppy to be doing anything.
Thanks
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-250...
NEW CHILDS METAL WAGON (A64281)
NEW CHILDS METAL...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A61572)
2025 GIYI GY-P45...
2017 CATERPILLAR 259D SKID STEER (A64279)
2017 CATERPILLAR...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
Sprayer (A64119)
Sprayer (A64119)
