powerscol
Well I finally got around to a bit of work today after the rain/snow the past few weeks. I am adding front hydraulics for the rear of my CT 235 to run a hay grapple. Some will say why did you not go with a 3rd function set up on the loader handle, but pricing made that a bit of a stretch for me.
First a lot of folks helped here answering questions and getting me pointed in the correct direction. J_J, SSDoxie and MtnViewRanch (aka Brian with Fit Rite Hydraulics) along with several venders were a great help.
Brian set me up with a kit. I think it was a first for him on my model tractor and he has been great to work with. He first sent out the connection hardware and a section or orange plastic hose to get the hose lengths figured out.
I then went about finding a place to mount the mid point dis-connect and settled on the left side under the floor board.
Once that was in I install the front mount on the loader cover plate, making sure the bolt heads would not contact the hard lines by using some foam as a spacer. I also cut some of the orange rubber hose and protected the lines from the cover mounting bolts.
Next on how I ran my hoses
