Bobcat CT225 starting issue/low oil pressure.
   / Bobcat CT225 starting issue/low oil pressure. #1
Matttj
Bobcat CT225
I have a Bobcat CT225 that I am having an issue with. Sometimes it starts but then dies 2 seconds later. Once in a while it starts it runs just fine and I can use it however long as I want as long as I dont turn it off. But most of the time it won't even turn over. I've noticed that when it won't start or when it starts and dies, the low oil pressure light comes on. I changed the oil back in December and have 8 hours on it since. I checked to make sure the oil level was fine. A little googling and talking to a coworker recommended replacing the oil pressure switch/sensor and nothing has changed. Has anyone had a similar issue with the same type of motor? Daedong 1.3L 3-cyl diesel.
   / Bobcat CT225 starting issue/low oil pressure. #2
If your key is on but the engine not running the oil pressure light will come on.
Completely normal.
   / Bobcat CT225 starting issue/low oil pressure. #3
It sounds like you have a starting issue. When was the last fuel filter change or full service?
   / Bobcat CT225 starting issue/low oil pressure. #4
Did you change the filter or just the oil? Try replacing the oil pressure sensor with a gauge temporarily.
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
NAPA 80 GALLON ELECTRIC AIR COMPRESSOR (A51248)
NAPA 80 GALLON...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
2009 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2009 MAC MFG 53'...
Ambulance (A52377)
Ambulance (A52377)
