Bobcat CT1025 - Starting issues
/ Bobcat CT1025 - Starting issues #1
ShoxEg
2020 BobCat CT1025
Hey Everyone
I am new to tractors and in general have been enjoying my CT1025...
But I see to be having some weird issues with it, since initial ownership, 1 hour on the clock when I got it, sometimes it was hard to start,
Following regular usage, couple hours of loader work, it will some times not restart when its a running temperature...
I have been trying to troubleshoot this quite a bit, I have been getting nowhere
Brough it back to the dealer at about 30 hours, I replicated the problem, they mention they look at it, a the same time I mention for them to do the full 50 hours initial service to make sure its A1
also requested that they properly run the hydraulic line to the loader, it was no in the brackets on the underside
Stayed there for over 3 weeks, pick it up, started... got a 600$ bill for the 50 hours
Anyhow they simply brush me away
winter past no issues, now started to do more loader work and its doing the same thing, not starting after continuous hours of loader work
In general the tractor works well when it works, but its a real PIA when its stop working in the middle of a project
any insights on this
Dealer is truly no help, there very busy with the big machines...
/ Bobcat CT1025 - Starting issues #2
Wild guess, could it be vapor lock in the fuel system? Try opening the cap to the diesel tank next time it happens and see if you hear a sucking sound. Might be worth checking the fuel level in the diesel filter and see if there is any air in it (hopefully its see through).
Good luck.
no vapor lock, fuel filter full
/ Bobcat CT1025 - Starting issues #4
Have you looked at all the safety features? When it doesn’t start, does it crank or is there nothing?
Does the engine stop in the middle of working or will it not restart after you turn it off for a break?
MoKelly
Seems that my fuel shut off solenoid might be bad,
I took it off and it started right away
played with it a little bit and seems to be working at the moment,
I will have to monitor
been having this issue since new
/ Bobcat CT1025 - Starting issues #6
Interesting. Now I guess you need to find out if the solenoid itself is defective or if some other issue caused the solenoid to do it’s job and shutoff the fuel supply.
Good luck. Good job so far in getting to the bottom of the issue.
MoKelly
/ Bobcat CT1025 - Starting issues #7
I have the same issue and more with my 1025. Dealer said something about removing some shims from the engine that were installed at the factory. Used it for an hour yesterday and both hydrostatics went out and tractor won’t restart. Less than 40 hours.
General update,
tractor been back and forth to the dealer twice
Dealer re shim the fuel injector pump, tractor is running much smoother... according to them is was off from the factory, definitely feels like a new machine... use it for two days, back to issue one, would not start anymore... I took off the replacement fuel stop solenoid that was supposedly change, can't confirm not sticker on this one... it started right up quarter turn.
Following this, I had the fuels stop solenoid off and turn the key,,, the solenoid clicks but the pin does not pull in, if I push the pin it stays in.... even funnier, its getting proper reading since the magnet is on
my temporally fix while waiting for a solenoid again is this
- activate glow plugs a couple of time
- Removed fuel stop solenoid
- Put key to on
- push pin in
- re install the solenoid
- turn key to turn over motor
- Enjoy rough start
- use tractor
While I use tractor I must never shut off the tractor or I have to restart my procedure
In other words, I leave it idling all the time, and must not activate one of the safeties.
hoping the 3 solenoid will actually work more then two days
I wonder if its twin brother Kioti has the same issues
/ Bobcat CT1025 - Starting issues #9
I used electrical circuit cleaner on each the four solenoids and wiring harnesses. Seems to be working well.
/ Bobcat CT1025 - Starting issues #10
New to the foum here, but I've been having almost the same issues as ShoxEg. As a matter of fact, I could have written his post! My tractor has currently been at the dealership almost 3 months. Anyone have a resolution?
/ Bobcat CT1025 - Starting issues #11
Hey Everyone
Did you ever get it fixed?
/ Bobcat CT1025 - Starting issues #12
I'm experiencing the same issue on my CT1021...and it's been randomly impacting the starting of the tractor pretty much since new
I can actually tell if it's going to start by the force of the "click" on the solenoid when I engage the key for the glow plugs. Of course the tractor was just in the dealer for 3 weeks to repair the hydraulic pump and it started with each attempt. I get it back home and it works flawlessly for 2 days and then won't start (I did get it to start by playing with the solenoid plug and tapping with a screwdriver (not saying that actually fixed it...but it did start afterwards)
I just want to be sure that someone resolved the issue by changing the solenoid...and it's not possibly related to some form of upstream voltage degradation (relay?) which is starving the solenoid from receiving full voltage and hence causing the issue
I'm ready to just purchase one outright (regardless of being under warranty)....as I don't have 2 weeks for the dealer to sit on it before looking at it.
Can someone:
1. please confirm that changing the solenoid resolved the problem for them
2. convey the part number for the solenoid (getting mixed results on fitment for part 7002157)
Thank you in advance!
/ Bobcat CT1025 - Starting issues #13
If the solenoid has any play where it lives.. try loosening the solenoid just a smidge and listen for the heavy click your use to..
Try throwing the throttle wide open..to assist with the
control rack getting into the start position..
If it’s a 1 wire solenoid, it uses the body of the solenoid for a ground..
MAKE SURE the solenoid and mounting surfaces are clean and free of paint and oil..
I hope this helps..
/ Bobcat CT1025 - Starting issues #14
I hope this helps..
Thank you for this guidance...I will attempt these steps when I am back at the barn
/ Bobcat CT1025 - Starting issues #15
Think of it this way..
The long rod hits the end of the pump control rack..
The rack is enclosed in the pump housing.. so the end of the solenoid rod has to hit squarely on the rack that’s in a “hole”..
If you’ve ever had the pump out or have seen a 360* pic of 1, you’ll understand what I’m trying to get across..
Good luck..
AND BTW.. when getting new solenoids.. MAKE SURE YOU HOLD THEM SIDE BY SIDE..
There ARE different length rods..
/ Bobcat CT1025 - Starting issues #16
Good luck..
Thank you for sharing your insight.
The service center came and picked up the tractor but of course it is starting fine for them. I did provide videos of it not starting that they are reviewing. They stated the tech thinks that it might be a relay. I'll keep everyone posted on the findings
/ Bobcat CT1025 - Starting issues #17
ok...so the dealer stated that they spoke with folks at Bobcat who instructed them to replace 3 relays (all can impact the voltage to the solenoid). They did so and dropped it off to me this morning. Please assume that this corrected the issue unless I report differently. :)
Thanks everyone!
Thanks everyone!
How is your running now, mine is back at the dealer for the x time... they change the entire wiring harness, check all the kill switches, replace the seat kill switch and hit kill switch... replaces relays... still getting the intermittent issue. So its back at the dealer again. There thinking know that it may be the key ignition that is finicky and not providing a proper signal for the fuel solenoid to pull... should be getting it back this week, we will see
/ Bobcat CT1025 - Starting issues #19
I’m having my 2nd 1025 taken to the dealer for the same issues. I say 2nd 1025 because the first was so bad that the dealer convinced the company to take the 1st one back and I received a new machine. Now my 2nd one is having the same starting issues as original poster stated as well. Forget about it starting at all when it’s below freezing outside.
/ Bobcat CT1025 - Starting issues #20
In October of 2022 we bought our CT 1025 with 27 hours on it worked great for about two half months January of this year it went in twice for the same issue not cranking over. The second time they replaced the starter and that worked for a few three weeks now less than month later it goes back in for not starting like the rest of the posts I have seen. This will be the third time in less than two months that it has to be worked on again. The dealership was less than happy the second and third time. Blaming it on fuel. This was their excuse. After some outside influence they were convinced that it needed to be looked at. So I guess we will see what happens when it comes back. But for the most part what ever Bobcat has a manufacturing issue with this and it needs to be fixed. If that means we have to get another tractor then so be it.
2021 Komatsu PC210L Hydraulic Excavator (A66734)
2021 Komatsu...
2012 Mitsubishi Fuso FEC72S Box Truck (A66736)
2012 Mitsubishi...
2014 FORD ESCAPE (A66091)
2014 FORD ESCAPE...
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
2005 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2005 FORD F150...
2011 Hyundai Sonata Sedan (A66738)
2011 Hyundai...
