BOBCAT A300
/ BOBCAT A300 #1
KERRTLE
LIVERMORE, CA
BOBCAT, CAT, JOHN DEERE, TYMCO, FORD, MASSIE FERG, TORRO,
DOES ANYONE KNOW HOW TO RESET THE CHANGE OIL SERVICE LIGHT ON THE RIGHT HAND CONTROL PANEL (BESS). THANKS.
/ BOBCAT A300
OK maybe I need to try explaining a little more in detail. I just serviced our Bobcat A300 skidsteerer (all wheel steer) after completion of the service. When you start the machine a warning pops us saying that it needs to be serviced and to contact your local Bobcat dealer. I am able to get into all the codes and testing screen but am lost at how to clear this message. Or at least reset the service counter. Any help greatly appreciated.
/ BOBCAT A300 #3
You might send a PM to the administrator to move this thread to the Bobcat Construction Equipment thread. More Bobcat owners will see it there.
/ BOBCAT A300
Thanks George. I just figured it out too.
/ BOBCAT A300
Ok I figured out how to reset the service clock. Without turning the machine on, press the lights button once to turn on the panel. Then all you have to do is press and hold the HIGH FLOW and AUXILIARY PRESSURE RELEASE buttons simultaneously until the rest appears. Hope this helps someone. I was spinning in circles for a while for something so simple.
/ BOBCAT A300 #6
That is good info to have. I haven't run into it yet, but I will at some point. The machines I have worked on are older and don't have that feature.
Thanks,
Brian
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
(4) Trail Quest 225/75R/15 Tires and Rims (A64047)
(4) Trail Quest...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
