BOBCAT A300
/ BOBCAT A300 #1
KERRTLE
LIVERMORE, CA
BOBCAT, CAT, JOHN DEERE, TYMCO, FORD, MASSIE FERG, TORRO,
DOES ANYONE KNOW HOW TO RESET THE CHANGE OIL SERVICE LIGHT ON THE RIGHT HAND CONTROL PANEL (BESS). THANKS.
/ BOBCAT A300
OK maybe I need to try explaining a little more in detail. I just serviced our Bobcat A300 skidsteerer (all wheel steer) after completion of the service. When you start the machine a warning pops us saying that it needs to be serviced and to contact your local Bobcat dealer. I am able to get into all the codes and testing screen but am lost at how to clear this message. Or at least reset the service counter. Any help greatly appreciated.
/ BOBCAT A300 #3
You might send a PM to the administrator to move this thread to the Bobcat Construction Equipment thread. More Bobcat owners will see it there.
/ BOBCAT A300
Thanks George. I just figured it out too.
/ BOBCAT A300
Ok I figured out how to reset the service clock. Without turning the machine on, press the lights button once to turn on the panel. Then all you have to do is press and hold the HIGH FLOW and AUXILIARY PRESSURE RELEASE buttons simultaneously until the rest appears. Hope this helps someone. I was spinning in circles for a while for something so simple.
/ BOBCAT A300 #6
That is good info to have. I haven't run into it yet, but I will at some point. The machines I have worked on are older and don't have that feature.
Thanks,
Brian
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
Deere 310L (A53317)
Deere 310L (A53317)
13042tx (A55973)
13042tx (A55973)
skeleton / rock bucket (A56857)
skeleton / rock...
