Bobcat 331
/ Bobcat 331 #1
nick 3rd
Bobcat 331
I have a 01 bobcat 331 d series I parked it 4-5 months ago was fine now starts fine but none of the controls work when I lower the left arm rest down the light comes on but nothing works any help would be appreciated
/ Bobcat 331 #2
I would check to see if you’re getting power to your safety lock out solenoid with a test light.
/ Bobcat 331 #3
Check the easy stuff. Fluid and fuses.
Did it have any hydraulic leaks? Sitting so long it may be low?
Does the blade work? The blade is a mechanical valve independent of the arm console/pilot controls, and electronic lockout. IE: under normal circumstances, the blade always works if the machine is running, even if the arm console is up.
2019 Maxx-D 40' Gooseneck Trailer w/ Mega Ramps (A64047)
2019 Maxx-D 40'...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
(2) 28LX26 TIRES & RIMS (A63745)
(2) 28LX26 TIRES &...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
Transfer tank (A61567)
