Check the easy stuff. Fluid and fuses.
Did it have any hydraulic leaks? Sitting so long it may be low?
Does the blade work? The blade is a mechanical valve independent of the arm console/pilot controls, and electronic lockout. IE: under normal circumstances, the blade always works if the machine is running, even if the arm console is up.
