Bluebird Houses
/ Bluebird Houses #21
/ Bluebird Houses
I built 8 new Bluebird houses today...
Cold and windy here so it was a good inside task...
Built from Cedar... cost $138.00 in materials to build 8... They do last a long time. I'm replacing ones that are well over 10 years old.
Regards,
Chris
/ Bluebird Houses
I finished up my bluebird house project...
Here are some pics... I'll wait till march to put them up.
Regards,
Chris
/ Bluebird Houses #28
Chris, very nice houses! Did you make sure that you can open up a part of the box to clean out the nests at the end of the year? It's important to do that only because they build up over a few seasons and they don't like to use them afterwords, not to mention the amount of crap (literally) that builds up from the youngsters before they leave the nest. It also helps to have access to the nest in case a sparrow slips in and you don't catch it until the nest is built, that way you can take their nest out and let the BB's try again.
Again, very nice houses though, they look great!
/ Bluebird Houses
Coopers,
The fronts are doors that will open for cleanout and nest checks.
Regards,
Chris
/ Bluebird Houses #31
Glenn9643 said:
I've found that a slot entrance helps with the sparrow problem around my place, and have replaced all my old round-hole entrance boxes with slot-boxes.
DANDR
What are you using for the demensions for the slot itself? I see 1 1/4", is that from the top of the face or the hight of the slot?
Steve
/ Bluebird Houses #32
Steve
I don't really think that I used these particular plans when I built mine, but I made my slot 1-1/8" high and that is what is recommended by NABS for a "slot" box.
/ Bluebird Houses
I'm going to do a small batch of these slot boxes to test and see if the sparrows really don't like them....
Has any done any large nesting boxes? Like for Owls, or Pileated Woodpeckers?
I did a big one for Squirrels and they used it...
I had one 4 holer filled with flying squirrels.
Regards,
Chris
/ Bluebird Houses #34
Chris, Where did you find plans for the squirrel houses?
I built a couple of northern flicker boxes this winter, they are made from 2x6's. Thats the largest I have done.
Jim
/ Bluebird Houses
Jim,
The Squirrel house I built was made from 1x12 rough sawn pine.
It was 24 inches tall and had if I remember right a 2 inch or maybe 2 1/2 inch hole.
It looked like the bluebird houses in shape without the block around the hole. Also no Copper on the roof .
I put it about 20 or so feet up in the tree. There have been lots of babies born in there... Sometimes you see three or four little heads sticking out and watching the world go by....
Regards,
Chris
/ Bluebird Houses #36
Thanks Chris, I am going to try a couple and see if I can attact a family from the nearby woods to my yard.
Jim
/ Bluebird Houses #37
Chris,
I have never seen any boxes with the metal roofs before. I know you said there is wood underneath but I would still be somewhat afraid of heat warming that box up too much, maybe not. But the thing that my blue's love to do is sit on top of the box. They do this for most of the day. With the metal I don't think they would be able to do that. Is this your first of boxes or have you used that style before? If you used this before did you have success.
murph
/ Bluebird Houses
Murph,
I have used this style of box for 15 years... I have not used them with the copper on the roof...
That copper will be brown then green within a year. I actually copied some boxes from Feathered Friend.
As for perching on the top... The top of the backboard is raw wood...
Regards,
Chris
/ Bluebird Houses #39
Chris,
If you can remember next summer let me know how they are working. If they work great I will be asking for you plan again and making a bunch just like yours for myself.
Good Luck
murph
/ Bluebird Houses #40
The old forum had a place you could subscribe to a thread. Where is that in this new forum??? Does anyone know here??
murph
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
White 5100 4R Planter (A66408)
White 5100 4R...
Sudenga 10 x 63 Portable Swing-away Auger (A66408)
Sudenga 10 x 63...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
Auger Cart (A65640)
Auger Cart (A65640)
