Blown PTO/mower strike
/ Blown PTO/mower strike #1
Anonymous Poster
Epic Contributor
I'm not exactly proud to admit this, but while using a rental tractor-- an older L30 Kubota, I ran into a tire in tall weeds that ended up blowing the PTO. I'm still waiting for the rental agency to contact me.
I realize I made a rookie move by not clearing the field before the grass got so thick, but after the old 5-foot brush hog flung a shear bolt (before the incident), a grade-8 annodized "shear-bolt", I called the company out to replace it. The guy showed up with the truck and put a grade 2 or 3 in the hole-- it had three marks on the head. He said it was not the proper one, but was alot better than the one that was flung. So anyways, I figure I have a good arguement that that shearbolt should have save the PTO. The rumor is $2000 dollars damage!? I might pay $500, but no more. Any opinions?
/ Blown PTO/mower strike #2
Yes, next time you rent pay the few dollars extra for the damage waiver......
Believe it or not, I wanted to sign one of them, but the only waiver they had was a theft and vandalism waiver. No damage waiver.
/ Blown PTO/mower strike #4
I could be wrong but a grade 2 bolt does not have any marks on it and is the softest and the one that usually is installed as a shear bolt, or at least that what was in mine until I put a slip clutch on it. If the bolt that was replaced had three marks on it , it was a hardened bolt and was probably the cause of the failure. did it shear when the bush hog hit the tire?
Bolt grades: No marks on head, grade one or two
Three hash marks let you know it is a grade five
Six marks is grade eight. Both five and eight are hardened, eight is stronger
If the PTO still worked after shearing a grade Eight bolt, it should have been fine with a grade Two.
The unit flung the grade-8 after mowing for several hours. I figure it must have been in place for quite some time before I took delivery. When the repair man came out, he left the grade-8 with me and I put it away in case some problem came up. He then replaced it with the annodized bolt with three hash marks. The bolt did not shear as I could turn the PTO shaft and rotate the blade. I feel the PTO was pre-stressed and primed for failure, as I demonstrated to the mechanic that it was difficult to engage when he came over to replace the bolt.
If I ever rent equipment again, I will rent only from outifts that carry damage insurance theat i can purchase. My sister- in-law works for the outift, which makes the whole situation rather unpleasant and she advised me before hand that waht they call the "insurance declaration" only covers theft and vandalism. I checked the fine print and sure enough... nothing covering accidental damage. They don't tell you this when you give them the money though, so if my foolishness can be a lesson to any rookies out there, make sure you are covered for damage, both in transit (by having your insurance agent add a binder for the day you trasnport the thing), and at your property, when operating the thing.
/ Blown PTO/mower strike #7
Is there anything in your homeowners policy that may help?
If the rental place supplied the tractor with the wrong grade shear bolt, and damage occured because the shear bolt was to strong, you should not be expected to pay anything. A shear bolt is a mechanical fuse to prevent damage.
If the rental place took out all the correctly rated electrical fuses and replaced them fuses with really high amp ratings and the electrical system got cooked while you were renting. Do you think you should pay?
If the rental place put the wrong type of oil or fuel in the engine and it died while you were renting, should you have pay to rebuild the engine?
As a renter, you have the right to expect the equipment will be set up properly. A failure because of operator abuse is different than a failure because of improper equipment setup. Keep the grade 8 bolt for proof.
Andy
Excellent parallel. Just what I wanted to hear. They may not even send me a bill, but in case they do, I'll be ready. You can really set yourself up when you're a rookie.
Look the whole rig over and make sure it's got the right fasteners, shear bolts, gages work, etc. Protect yourself.
/ Blown PTO/mower strike #11
Johnny:
Am I missing something? Did they come out and replace the shear bolt and then you could continue hogging? If so then then the shear bolt did it's job and there should be no charge whatsoever. I beleve that it is to be expected that the shear bolt will do it's job from time to time as people hit all types of stuff. I always add 2 to the number of hash marks to get the grade. None makes it a 2, 3 make it a 5, 6 marks make it an 8. Most people use a 2 or a 5. They might have used an 8 so they didn't have to come running out as much. If the hog worked after the shear bolt replacement, you owe then nothing !!!!! Jason
I guess I kind of complicated the explanation. First, I called the mechanic out to find out where the lose grade-8 bolt laying on top of the deck mower was supposed to go. He found the missing hole-- it was being used as a shear-bolt on the deck mower. He replaced it with a grade-5 bolt, remarking that it was not the right one, but that it would be better than the Grade-8. He left and I got on the mower and promptly ran over a tire (without rim in deep grass). The grade-5 shear bolt DID NOT DO IT'S JOB! IT DID NOT SHEAR!-- and the PTO was damaged. By the way, I like the way you add "two" to the hash marks to come up with the grade.
Tracy
/ Blown PTO/mower strike #13
I gotta think that I would only feel responsible for any damage that occurred downstream of the shear bolt. If the bolt did not shear either it was a defective bolt, it was installed incorrectly or the pto was ready to let go at any moment anyway.
Jeff
/ Blown PTO/mower strike #14
Not trying to stir up any more foreboding. But if that shear bolt failed to releive the shock. It could have traveled both ways and possibly damaged the pto at the tractor end also. So if it was the rental ccompanies responsibility for not properly replaceing the shear bolt, they may have placed themselves in a position of responsibe liabilty for any repairs to your tractor. Even if your tractor is not damaged just this type of explanation might help you convince them that the cost of repair is not your responsibility.
/ Blown PTO/mower strike #15
I have to agree with Jeff, that shear bolt should have protected the driveline, perhaps as others have stated, the driveline was ready to go anyway. Have they come after you for the money ?
No the big guys with the dirty hands and bent noses have not showed up on my porch step. I hear this sometimes takes a few months though. The rental bill had a footnote that said I would be billed for the damage to the PTO when the work was done.
/ Blown PTO/mower strike #17
Johnny, if the repairman represented the rental company, and you can prove he installed a grade 5 or stronger shear bolt, I would tell them to sue me. You have a great court case.
/ Blown PTO/mower strike #18
Having a relative working at the rental place may complicate things. In the interest of family bliss, it might be better to pay the bill and chalk it up to experience......unless you don't like that relative anyway./w3tcompact/icons/smile.gif
Jeff
Yeah, at least I might just pay some of it to keep things tight.
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
2007 Freightliner Semi Truck (A66285)
2007 Freightliner...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
New/Unused Wolverine 44in Mini Grapple Bucket (A65583)
New/Unused...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
