Blowing white smoke
   / Blowing white smoke #41
Sounds like blown head gasket. Can cause major motor damage with continued motor operation
I bent a grade 8 1/4-20 bolt that was used to mount the flange. But I got it off. The solution was a bigger hammer! Put as much pressure as you can on the puller, then just beat the **** out of the center bolt you're pulling on.
I broke everything I threw at it until this point, but it's safely off. By safely i mean in reusable ocndition. I need to reuse it, toherwise it'd have gotten the beating of a lifetime, not the gentle treatment I gave it. I need to make a new shaft and plate adapter for the new engine so I can keep the variable speed.
Next up is the 4th engine mount bolt. 3 are off, but that 4th... I had to dig for 20 minutes before I could even see it, and I have to take the starter off to get to it.
Engine out, hydro pump off, getting the engine mounts/plates for the new engine ready.
   / Blowing white smoke #46
Hey, it’s the dude from Mythbusters! :)
   / Blowing white smoke #49
So, what issues lie ahead?
  • Motor Mounts
  • Clearances
  • Hydraulic Pump & Plumbing
  • Radiator & Fan
  • Muffler
  • Linkages
  • Access (oil filter, drain, etc)
  • RPMs
  • Clutch/Belt/Alignment
  • Fuel Pump & lines
I hope you don't run out of projects, because you are fun to watch.
Motor mounts are easy, hydraulic pump/plumbing is easy, radiator/fan is easy.
Clearances are tricky. I have to find a half inch. The motor is 21" and the wall to the belt pulley is 20.5". Last I checked motors weren't very pliable, nor bobcat frames. So I may have to get creative.
The funny thing about this is it's a hose to the fuel and a pulley. No clutches, they're in the chain cases. Belt alignment is really the only hurdle I need to figure out. And I can't really even start on that before I get the engine in for a test fit, which means mounts come first.
If I run out of projects, I think I would immediately die of boredom. You might like my kubota cab and power steering threads. But as time goes on it seems i'm getting more ambitious. And I don't like paying people to do something I can do myself. And I'm learning more stuff.
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2017 Ford Transit 150 Cargo Van (A55852)
2017 Ford Transit...
UNUSED FUTURE BC63 57" HYD BRUSH CUTTER (A57193)
UNUSED FUTURE BC63...
Misc Gas Equipment (A56469)
Misc Gas Equipment...
Ford Metal Tailgate Art (A55853)
Ford Metal...
