Blowing white smoke
   / Blowing white smoke
Okay,If I am understanding this right, The old version was variable speed with a belt drive with a CVT primary and secondary clutch like a snowmobile has. The Kubota diesel version will be a single speed with a chain drive?
The hydraulic pump for the rams on the loader arms and bucket is already on the Kubota? (I didn't understand your link)
In any case, things are moving along.
PS: Why don't you paint things up pretty when you have everything apart?
The old system had a pulley that had a belt for primary drive to the jack shaft. Both pulleys were bowed out, so you could compress the engine side and it would get closer together, pushing the drive pulley out, increasing hte diameter. On the jackshaft side it was spring loaded, so if you increased the engine side, it would suck the pulley in spreading the two halves pushing the spring out. Widening the drive pulley would let the pulley go in, and the jack shaft side spring load back to close together. The engine side is controlled by a hydraulic cylinder that pushes the two sheaves together or retracts them. Then the jackshaft side was spring loaded and adjusted to accomidate the engine side. Each pulley was 2 pieces that could vary in width, increasing or decreasing diameter based on how wide it was.
Unfortunately, I don't have a good picture of it, which would make it much easier to understand. I have attached a picture that shows hte hydrauulic line that goes to the drive sheave piston, single acting, that varies the drive sheave width, increasing or decreasing the diameter, and pulling jack shaft to accomidate.
I'll clean it up as I go, but if it's painted it's good, if it's covered in oil and painted, better. No better rust prevention. My machines aren't show machines, they're work machines. If they're not rusting, they're good for continued opperation.
   / Blowing white smoke #62
Like this....
I am amazed about how clean the steering clutches look in all the Youtube videos.
Is the link to the pump you referenced a hydraulic pump or a oil pressure pump?
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
UNUSED JCT 84" HYD DOZER BLADE (A57193)
UNUSED JCT 84" HYD...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A57193)
UNUSED FUTURE MINI...
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
golf cart (A56859)
golf cart (A56859)
1762 (A57192)
1762 (A57192)
