blowing fuses
/ blowing fuses #1
RandyT
Elite Member
BEECHER CITY, IL
KIOTI DK45S
Had an interesting lawnmower problem come into the shop today. Kept blowing fuses. Owner claims he started it about two days ago and no problems, and this time he hit the key and it blew the 20A fuse to the whole mower.
Put a new fuse in and unplugged everything to try to isolate the short and got everything plugged back in and still didn't blow the fuse until I tried to start the engine and the starter turned but gear didn't engage the flywheel. After that couldn't get anything to response even with different fuse.
Now the interesting part I decided to check the battery voltage and put the red lead of meter on + and the black lead on - and the meter read -11 volts. The battery has reversed polarity and was trying to turn the starter backwards which is why it was blowing fuses.
/ blowing fuses #2
Randy, check the wiring on the electric clutch PTO. Sometimes the insulation on the wiring will wear off and the bare wires will short to the frame. I had this problem. I insulated the wires with electrical tape, then replaced the fuse. No more problems.
2022 EZ-GO ELITE...
2002 Harmon Steel Barrel Asphalt Tanker Trailer (A64194)
2002 Harmon Steel...
2013 FREIGHTLINER CASCADIA T/A 6X4 DAY CAB TRUCK (A67147)
2013 FREIGHTLINER...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
1991 Polar MC 312 General T/A Chemical Tanker Trailer (A64194)
1991 Polar MC 312...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
