Blow by
/ Blow by #2
Blow by is when the ignighted fuel/air mixture in the cylinder "blows by" the piston rings and into the crankcase. You can tell by the smoke coming out of the crankcase vent. Hope this helps
/ Blow by #3
Another way to tell is the oil residue at the engine crankcase vent. If it is a modern engine, you will find the oil fill cap "leaking" vapors. If it is real bad, I have seen it push oil out the dipstick tube.
/ Blow by #4
Several addtional things to look for:
1. Crankcase oil that gets dirty very quickly.
2. Remove your oil filler cap with the engine running at low rpm and put your hand over the filler hole. You may be able to feel the puff-puff-puff at very low rpm.
3. When the engine is hot, remove the oil filler and put a sheet of paper or light cardboard near the filler. It will move with air puffing out. This may be hard to do/see if your fan is also close-by.
4. With severe blowby, you'll have oil and smoke coming out of any crankcase vent opening.
5. Do a compression check. All or some cylinders will show low compression. Spray some light oil in the cylinder at the sparkplug hole if it's a gas engine. You should see a big jump in compression with oil in the cylinder.
/ Blow by #6
UNUSED WOLVERINE LL-12-78W 78" LAND LEVER (A62131)
UNUSED WOLVERINE...
2016 Ford F-750 Service Truck, VIN # 1FDXF7DE8GDA03979 (A61165)
2016 Ford F-750...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
CLUBCAR CARRYALL 1700 DISEL GOLF CART (A62130)
CLUBCAR CARRYALL...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A62130)
2008 INTERNATIONAL...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
