Blow by
/ Blow by #2
Blow by is when the ignighted fuel/air mixture in the cylinder "blows by" the piston rings and into the crankcase. You can tell by the smoke coming out of the crankcase vent. Hope this helps
/ Blow by #3
Another way to tell is the oil residue at the engine crankcase vent. If it is a modern engine, you will find the oil fill cap "leaking" vapors. If it is real bad, I have seen it push oil out the dipstick tube.
/ Blow by #4
Several addtional things to look for:
1. Crankcase oil that gets dirty very quickly.
2. Remove your oil filler cap with the engine running at low rpm and put your hand over the filler hole. You may be able to feel the puff-puff-puff at very low rpm.
3. When the engine is hot, remove the oil filler and put a sheet of paper or light cardboard near the filler. It will move with air puffing out. This may be hard to do/see if your fan is also close-by.
4. With severe blowby, you'll have oil and smoke coming out of any crankcase vent opening.
5. Do a compression check. All or some cylinders will show low compression. Spray some light oil in the cylinder at the sparkplug hole if it's a gas engine. You should see a big jump in compression with oil in the cylinder.
/ Blow by #6
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62130)
KNOW BEFORE YOU...
2019 CATERPILLAR 259D3 SKID STEER (A62129)
2019 CATERPILLAR...
2022 CATERPILLAR 307.5 EXCAVATOR (A62129)
2022 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
