Block heater
   / Block heater #1
olefaht
western Maine
Deere MC, Kubota L4600
I have a L4600 that I have used very little in cold weather. Starts fine with glow plugs down to 30F. There is a block heater installed which I have never used, and in advance of wanting to start it up in 20F or less temps this week I plugged it in. I can't tell if it is actually doing anything; touching the exposed portions of the device after an hour doesn't seem to be any warmer than the surrounding metal. My question is whether the 'business end' of the heater is way inside the block and won't affect the outer portions, or should there be some noticeable temperature rise where the device is mounted?
   / Block heater #2
I'd expect the block to feel moderately warm compared to ambient below freezing temps at least. Try pulling the oil dipstick before plugging in the heater, note the temp (How warm the oil feels). Then plug it in and see if the oil warms up.
   / Block heater #3
Fingertips are not very accurate temperature measuring devices.
Most block heaters are a only few hundred Watts and are not going to provide enough temperature elevation to an engine block in frigid weather to be felt by finger tips.
Use a contact thermometer or thermal camera to actually determine if heating is occuring.
   / Block heater #4
Or get a killowatt meter for about $10 on Amazon and check to see it is using some wattage, and it is a good tool for other projects around the house.
   / Block heater #5
Any block heater whether in block or external you can hear them work. And yes after being plugged in for half hour or so the block should feel warm on smaller tractors. Larger ones take more time.
   / Block heater #6
And yes after being plugged in for half hour or so the block should feel warm.
Even if it could heat it the block to 70 deg F, which it can’t in subfreezing conditions due to ambient heat loss, it will feel cool to the touch since the human body is well over 95 deg F.
   / Block heater #7
Any time you want to check any of my tractors after they been plugged in you are welcome to. I listen for them to kick on most of them. The external ones I can watch for the snow to immediately melt off the block heater. On the smaller tractors the snow is starting to melt off the hoods after about an hour. On the 6 cylinders takes it a couple hours. Yes you can feel the heat.
   / Block heater #8
I can hear my block heater, or I should say I can hear the water heating, and it warms my engine enough in an hour that I can feel it by touching the valve cover.
   / Block heater #9
If it's an OEM block heater, it is not thermostatically controlled and should be on all the time when plugged in. Yes, you should feel some warmth.
If it's an aftermarket heater, it may have a thermostat and the ambient temperature might not be low enough for it to activate.
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2018 KOMATSU WA200-8 WHEEL LOADER (A60429)
2018 KOMATSU...
New Holland 308 Manure Spreader (A59814)
New Holland 308...
Toyota SR1-BET35 3,500LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
International S1900 (A56438)
International...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
