Block Heater
   / Block Heater #1
XmasTreeGuy
Crossnore,NC
Mahindra 6110
I just bought a 6110 Mahindra,only 11 hrs. so far. Is anyone using a block heater? If so where did you buy it?Temps have been very low here & I'd like to have a block heater.
   / Block Heater #3
My 5035 has a pumpkin shaped cast iron ' device ' in the lower radiator hose to install a standard 3/4" screw in heater... You can get them on Ebay or Amazon... I bought a ' Kat's 11619 600 watt ' to put in mine... but will not be putting it in until this summer. Your tractor may have the same inline heater spot.. Good luck, Jerry...
   / Block Heater #4
Looking at the parts site, your 6110 uses a different screw in heater than my 35 series. Says it screw into left side of maybe the block, where the pumpkin shaped thing in mine is called a B/H adapter, probably bottom hose... Your dealer can fix u up with one.... :)
   / Block Heater
Thanks for the replies. I'll check block. What parts site are you looking at Jerry? New Mahindra owner here.
   / Block Heater #6
Can't remember which one I looked at... but if you Google ' Mahindra 6110 block heater ' you will get hits like...
Error
There are some parts dealers on TractorByNet, too... This link says 'ERROR', but works .... Good luck, Jerry
   / Block Heater
I took a quick look this afternoon and didn't see the plug in the block for the heater. I'll take a closer look soon. I don't see anyway to use one of the in hose heaters,so it will have to be an in block heater looks like.
   / Block Heater #8
I have been looking at Wolverine adhesive pad heaters that is glued with a 3M adhesive to the oil pan externally. Has anyone else looked or used a Wolverine?
   / Block Heater #9
We have installed several block heaters in the 6110, you have to knock out the freeze plug on the side of the block, tap in the adapter and thread in the block heater. If I remeber correctly around $100 shipped to you. Can have it to you in the matter of a few days.
   / Block Heater #10
Hi Jerry,
I have been searching everywhere, including google, to find the info you provided here re: coolant heater for my 2010 5035. The glow plug went away last winter so had to keep the old girl in my 45 degree heated garage, preventing my winter projects from getting done! :banghead:
so Thank You for this valuable information!
I am about to order the heater and wanted to know if you installed it this summer and did it fit without hitting internally? Is it working properly in your 5035? Would appreciate a follow up. You can reach out to my via my email address if it's more convenient: cfcbassman@gmail.com
Thanks again.
atb
Gus
:drink:
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A50323)
2008 Ford E-350...
2010 JOHN DEERE 1110E FORWARDER (A51246)
2010 JOHN DEERE...
2006 Ford F-150 Crew Cab Pickup Truck (A50323)
2006 Ford F-150...
2012 JOHN DEERE 310SJ BACKHOE (A52472)
2012 JOHN DEERE...
TITAN - SET OF 18.4R46 NEW AG TIRES (A52748)
TITAN - SET OF...
2008 Toyota RAV4 AWD SUV (A50324)
2008 Toyota RAV4...
